System.Exception: Invalid argument : Invalid graphic ID!
4228
05-21-2015 10:05 AM
RobertKennedy
Hi All,
I'm curious is anyone has seen this exception before and had any ideas on resolution.
Background:
Basically we periodically create and remove graphics in a GraphicsOverlay, something akin to the following:
Add:
MapPoint pt = new MapPoint(lon, lat, elev, SpatialReferences.Wgs84);
pt = GeometryEngine.Project(pt, myMapRefSsytem) as MapPoint;
Graphic g = new PictureMarkerSymbol();
g.SetSourceAsync(new Uri(iconAnno.IconPath));
myGraphicsOverlay.Graphics.Add(g);
Remove:
myGraphicsOverlay.Graphics.Remove(f.Gfx);
RobertKennedy
Apparently submitted early.
Anyway, that typically works fine, but occasionally the arcgis API throws the exception listed below.
Anyone have any ideas?
   at RuntimeCoreNet.Interop.HandleException(Boolean retVal)
   at RuntimeCoreNet.CoreGraphicsLayer.RemoveGraphics(Int32[] ids)
   at RuntimeCoreNet.CoreGraphicsLayerWrapper.RemoveGraphicsInternal(RemovalInfo removals)
   at RuntimeCoreNet.CoreGraphicsLayerWrapper.UpdatePendingGraphics()
   at Esri.ArcGISRuntime.Controls.ViewBase.MapBatchProcess()
   at Esri.ArcGISRuntime.Controls.ViewBase._batchUpdateTimer_Tick(Object sender, Object e)
   at System.Windows.Threading.DispatcherTimer.FireTick(Object unused)
   at System.Windows.Threading.ExceptionWrapper.InternalRealCall(Delegate callback, Object args, Int32 numArgs)
   at MS.Internal.Threading.ExceptionFilterHelper.TryCatchWhen(Object source, Delegate method, Object args, Int32 numArgs, Delegate catchHandler)
   at System.Windows.Threading.DispatcherOperation.InvokeImpl()
   at System.Windows.Threading.DispatcherOperation.InvokeInSecurityContext(Object state)
   at System.Threading.ExecutionContext.RunInternal(ExecutionContext executionContext, ContextCallback callback, Object state, Boolean preserveSyncCtx)
   at System.Threading.ExecutionContext.Run(ExecutionContext executionContext, ContextCallback callback, Object state, Boolean preserveSyncCtx)
   at System.Threading.ExecutionContext.Run(ExecutionContext executionContext, ContextCallback callback, Object state)
   at System.Windows.Threading.DispatcherOperation.Invoke()
   at System.Windows.Threading.Dispatcher.ProcessQueue()
   at System.Windows.Threading.Dispatcher.WndProcHook(IntPtr hwnd, Int32 msg, IntPtr wParam, IntPtr lParam, Boolean& handled)
   at MS.Win32.HwndWrapper.WndProc(IntPtr hwnd, Int32 msg, IntPtr wParam, IntPtr lParam, Boolean& handled)
   at MS.Win32.HwndSubclass.DispatcherCallbackOperation(Object o)
   at System.Windows.Threading.Dispatcher.LegacyInvokeImpl(DispatcherPriority priority, TimeSpan timeout, Delegate method, Object args, Int32 numArgs)
   at MS.Win32.HwndSubclass.SubclassWndProc(IntPtr hwnd, Int32 msg, IntPtr wParam, IntPtr lParam)
   at System.Windows.Forms.UnsafeNativeMethods.DispatchMessageW(MSG& msg)
   at System.Windows.Forms.Application.ComponentManager.System.Windows.Forms.UnsafeNativeMethods.IMsoComponentManager.FPushMessageLoop(IntPtr dwComponentID, Int32 reason, Int32 pvLoopData)
   at System.Windows.Forms.Application.ThreadContext.RunMessageLoopInner(Int32 reason, ApplicationContext context)
   at System.Windows.Forms.Application.ThreadContext.RunMessageLoop(Int32 reason, ApplicationContext context)
   at System.Windows.Forms.Application.Run(Form mainForm)
   at MyApp.Program.Main() in e:\Fuse\Desktop\ESRIMap\source\MyApp\MyMain\Program.cs:line 198
   at System.AppDomain._nExecuteAssembly(RuntimeAssembly assembly, String[] args)
   at System.AppDomain.ExecuteAssembly(String assemblyFile, Evidence assemblySecurity, String[] args)
   at Microsoft.VisualStudio.HostingProcess.HostProc.RunUsersAssembly()
   at System.Threading.ThreadHelper.ThreadStart_Context(Object state)
   at System.Threading.ThreadHelper.ThreadStart()
AsserSwelam1
Hi Robert,
Can you attach a reproducible app to see the issue?
Asser
RobertKennedy
Hi Asser,
Sure thing, I was hoping to see if I'd get any quick responses before needing to pull it out of our product and into a stand alone app, but I can certainly look into that.  I'll keep you posted.
Cheers,
Bobby
MichaelBranscomb
Esri Frequent Contributor
Hi Bobby,
We have fixed a couple of issues recently which might give rise to this exception - which is why we are keen to test your scenario on the latest internal build.
Are you sharing one layer instance between multiple active MapViews?
Cheers
Mike
