Synchronous HitTest
3085
04-04-2016 10:33 AM
KerenMoses1
I am using ArcGIS Runtime for .Net 10.2.7.
I have an application that draws graphics dynamically every few seconds.
Due to application limitations, I have to perform a synchronous hit test.
I tried waiting for the HitTestAsync task, but the application gets stuck, and the task's state is always 'WaitingForActivation'.
Is there any way to perform hit test synchronously?
Keren
dotMorten_esri
Esri Notable Contributor
How are you "synchronously" waiting for hittest to complete? If you're blocking the async task with a .Wait() call, you WILL hit a deadlock. Synchronous hit testing isn't supported.
KerenMoses1
Will it be supported in future versions?
Our application architecture forces us to work synchronously..
dotMorten_esri
No on the contrary async is the design pattern going forward.
Are you sure you can't change your application architecture? Forcing synchronous processing has a lot of downsides, which is why most UI frameworks has moved away from this.
