Switch modules cause MapView deadly using SingleInstance mode
761
06-29-2017 02:22 AM
xiaoguangyan
New Contributor III
Hi, I have meet a problem, We use SingleInstance mode in our project, when do some interactions in current module and then switch to other modules, the map is likely to be locked and deadly, can't be navigate and interact with the map. In the attached sample codes, selects features and then tab to another do some interactions, the map will is likely to be locked and unoperational.(tab switch in left-up) sample codes are attached, will you please help to test my codes and if any solution to solve this please do let me know. Thanks in advance
Tags (1)
GregDeStigter
I looked at the sample you provided and I think the issue that you've found was a runtime bug in v100.0. Your sample seems to work with the newly released v100.1. Could you try it and confirm?
xiaoguangyan
New Contributor III
Hi Greg
After upgrate to 100.1, the sample do works in the way as I describe in question, but if you switch tab quickly the mapview will be white with no map in view
