Strange behavior of the sketch editor on iOS devices
789
03-14-2019 06:27 AM
SandeepKuniel1
New Contributor III
The sketch editor does not seem to record the correct coordinate, when the magnifier is used on an iOS device.
In order to replicate the issue, i have attached a video <ArcGIS Runtime Sample, "Sketch graphics on the map">.
Notice, in the video i am trying to draw a polyline.
..Long pressing on the map to invoke the magnifier, when i lift my finger to stop the magnifier the graphic point does not fall in the same location as the magnifier, instead i see the graphic point in the North-West.
The same sample works fine on an Android Device.
I am using
ArcGIS Runtime 100.4.0
Xamarin Forms 3.5
Device with iOS 12.1.4
TonyWakim
I was able to reproduce the behavior on 100.4.  When using the magnifier, the Sketch editor does not use the right coordinates.
I am not able to reproduce with our current development build; Please test again with the next release when it is out.
Tony Wakim
Esri - ArcGIS Runtime .Net
TonyWakim
Tony Wakim
SandeepKuniel1
New Contributor III
Looks like this issue has been fixed in the current build 100.5, so closing this issue.
