Sketch Editor hard crash in MAUI
3016
8
05-13-2022 02:51 AM
hayer
Sketch Editor makes the program crash when moving a vertex. Deleting vertices works fine.
Happens when using;
  • Esri.ArcGISRuntime.Maui version 100.14.0-preview2  (also happend in earlier versions)
  • Esri.ArcGISRuntime.WinUI version 100.14.0
Exception
Faulting application name: MyProgam.exe, version: 1.0.0.0, time stamp: 0x62571213
Faulting module name: CoreMessagingXP.dll, version: 10.0.22467.1020, time stamp: 0xcb3186f5
Exception code: 0xc000027b
Fault offset: 0x0000000000095b2c
Faulting process ID: 0x0x10A0
Faulting application start time: 0x0x1D866AD9E26D744
Faulting application path: C:\Users\<...>\MyProgram.exe
Faulting module path: C:\Program Files\WindowsApps\Microsoft.WindowsAppRuntime.1.0_3.469.1654.0_x64__8wekyb3d8bbwe\CoreMessagingXP.dll
Report ID: 96db5917-feb8-4250-b12a-3870ea711455
Faulting package full name: 42b5bb5f-a561-4075-b936-0286994fd075_1.0.0.1_x64__9zz4h110yvjzm
Faulting package-relative application ID: App
TargetFramework is net6.0-windows10.0.19041
TargetPlatformMinVersion is 10.0.19041.0
Edit:
One, of many, offending polygons
{"rings":[[[28.309655000000078,70.540905000000066],[28.403449000000023,70.510430000000042],[28.399771000000044,70.500051000000042],[28.35941500000007,70.487775000000056],[28.33516000000003,70.476974000000041],[28.309078000000056,70.450761000000057],[28.304184000000078,70.446040000000039],[28.295386000000065,70.439965000000029],[28.28324200000003,70.433109000000059],[28.268496000000027,70.425224000000071],[28.25207400000005,70.418677000000059],[28.227295000000026,70.410380000000032],[28.223170000000039,70.408862000000056],[28.218629000000078,70.406914000000029],[28.215925000000027,70.405530000000056],[28.213705000000061,70.404005000000041],[28.200345000000027,70.405896000000041],[28.199266000000023,70.405929000000071],[28.199054000000046,70.405939000000046],[28.198916000000054,70.405992000000083],[28.194075000000055,70.40670300000005],[28.192904000000055,70.406964000000073],[28.181576000000064,70.409444000000065],[28.179857000000027,70.408524000000057],[28.178476000000046,70.409169000000077],[28.175197000000026,70.409530000000075],[28.171282000000076,70.409568000000036],[28.165715000000034,70.409115000000043],[28.165634000000068,70.409203000000048],[28.165445000000034,70.409338000000048],[28.165144000000055,70.409470000000056],[28.164892000000066,70.409635000000037],[28.164721000000043,70.409825000000069],[28.164509000000066,70.410019000000034],[28.164243000000056,70.410283000000049],[28.164035000000069,70.410371000000055],[28.163829000000078,70.410431000000074],[28.163745000000063,70.410492000000033],[28.163700000000063,70.410584000000028],[28.163732000000039,70.410669000000041],[28.163766000000066,70.410845000000052],[28.163861000000054,70.410942000000034],[28.163830000000075,70.411027000000047],[28.163722000000064,70.411110000000065],[28.163490000000024,70.411156000000062],[28.163278000000048,70.41121400000003],[28.163042000000075,70.411332000000073],[28.162894000000051,70.411421000000075],[28.162751000000071,70.411577000000079],[28.162631000000033,70.411681000000044],[28.162418000000059,70.411737000000073],[28.162083000000052,70.411801000000082],[28.161881000000051,70.411914000000081],[28.16161100000005,70.412030000000073],[28.157516000000044,70.414259000000072],[28.129609000000073,70.415067000000079],[28.115793000000053,70.42289500000004],[28.143167000000062,70.441414000000066],[28.155598000000055,70.447324000000037],[28.171614000000034,70.45575000000008],[28.185207000000048,70.460771000000079],[28.196145000000058,70.465699000000029],[28.235099000000048,70.468457000000058],[28.274880000000053,70.478925000000061],[28.284531000000072,70.493888000000084],[28.320109000000059,70.498712000000069],[28.318239000000062,70.506216000000052],[28.309655000000078,70.540905000000066]]],"spatialReference":{"wkid":4258}}
dotMorten_esri
Esri Notable Contributor
Thanks for the repro. I'm able to reproduce now. There's a limitation in the sketch editor editing geometries in a different spatial reference than the mapview. Granted that error could be better and shouldn't crash like this, but for now, you can address it by reprojecting before editing:
var editedGeom = await mapView.SketchEditor.StartAsync(GeometryEngine.Project(geom, map.SpatialReference));
PreetiMaske
I ported over forms SketchOnMap sample to MAUI and tried deleting the vertex and did not see any crash. Would you like to share your test app with a simple repro? I would be happy to try and see if I can reproduce it as well.
Preeti
hayer
Thanks for taking your time to test it.
Deleting vertices works fine. Its moving any of them which causes the crash. It doesn't happen for all polygons - only some. Seems to be more common polygons with many vertices, >200. Don't have the data accessible right now but I will post one of the offending polygons later to night 🙂
hayer
dotMorten_esri
I haven't been able to reproduce this either. Any chance you could share a small sample that reproduces this behavior?
hayer
hayer
@dotMorten_esri any idea what might be causing this?
@PreetiMaske feel free to take a look at the repo linked above 🙂
dotMorten_esri
hayer
Ah, okay! Thanks. Didn't think that would cause an issue, and as you state the error message could maybe be a tad better.
Using workaround you suggested for now.
