Show a gpkg file as the basemap
2414
7
03-05-2018 08:33 AM
AaronMurphy3
New Contributor III
Hi everyone.
Pretty simple question, does anyone know how I could show a gpkg file as a basemap? The docs haven't helped and a few samples mention geopackages but then use .shp files.
Aaron
NagmaYasmin
Occasional Contributor III
Hi Aaron,
You could use the code below to display a gpkg file:
Map myMap = new Map();
// Get the full path
string geoPackagePath = "..\\..\\AuroraCO.gpkg";
// Open the GeoPackage
GeoPackage myGeoPackage = await GeoPackage.OpenAsync(geoPackagePath);
// Read the raster images and get the first one
Raster gpkgRaster = myGeoPackage.GeoPackageRasters.FirstOrDefault();
// Make sure an image was found in the package
if (gpkgRaster == null) { return; }
// Create a layer to show the raster
RasterLayer newLayer = new RasterLayer(gpkgRaster);
await newLayer.LoadAsync();
myMap.Basemap.BaseLayers.Add(newLayer);
MyMapView.Map = myMap;
await MyMapView.SetViewpointCenterAsync(39.5517, -104.8589);
gokg
Attached is the sample application. Hope that helps.
AaronMurphy3
New Contributor III
Thanks Nagma, that works great!
However, I have come to realise that this will not completely fulfill my requirement. Is it possible to use a mosaic file system with ArcGIS .NET? For example, have the image split into many tile PNGs across multiple folders and when you zoom in/out of the map it requests the new tiles from a server using z/x/y parameters?
Aaron
NagmaYasmin
I believe you may use MosaicDatasetRaster.AddRastersAync() method to add rasters to mosaic dataset. Have you tried this?
MosaicDatasetRaster.AddRastersAsync Method
AaronMurphy3
New Contributor III
I saw it earlier but couldn't quite work out how to use it. Could you perhaps provide an example of how to use it with a service or even just locally? Currently with another map system we are able to just provide a url like so "../Diagrams/{z}/{x}/{y}.png"
NagmaYasmin
Hi Aaron,
MosaicDatasetRaster takes sqlite datsset, it doesn't take png/tiff file though. So looks like the API won't work for you unless you use .geodatabase.
AaronMurphy3
New Contributor III
I see!
We currently use TPK files for our maps and serve them locally. However, our customer has shown interest in us including DWG/DXF files in the ArcGIS viewer. Would you happen to know if this is possible at all? Perhaps with some form of conversion?
Aaron
NagmaYasmin
Hello,
In ArcMap, you can export this type of file to shapefile and then consume that shape file in runtime application.
