Rectangle not getting displayed on map ?
1404
13
07-31-2018 07:50 AM
VijitWadhwa
New Contributor III
I tried to zoom the map by drawing a rectangle on the map (i.e zooming a specific area) , the map zooms to the extent on which rectangle gets drawed, but I am unable to see the rectangle on my screen , I am sharing the code, can anyone tell me , what is my mistake ?
dotMorten_esri
Esri Notable Contributor
The editor only allows you to sketch a geometry, and is temporary while sketching. What you do with it afterwards is up to you. In this case you need to add it to the mapview afterwards. For instance by using a GraphicsOverlay.
VijitWadhwa
New Contributor III
No , I don't want it to persist on mapView , but the problem is , I can't
even see the trail of rectangle been drawn.
VijitWadhwa
New Contributor III
I don't want to add the rectangle on the map, I just want to see ,while it
gets drawn temporarily , but I am unable to see that. The map zooms to the
extent of the covered area while mouse is down , but I am unable to see the
trail of rectangle.
VijitWadhwa
New Contributor III
This problem occurs if a measuring toolbar is present on the screen, If I remove the measuring toolbar then i can see the rectangle, Otherwise the rectangle is not visible. How to resolve this ?
JenniferNery
Hi Vijit,
I think I know what the problem is now that you mention MeasureToolbar.
Can you check and set ` MyMapView.SketchEditor.IsVisible = true;`. The measure toolbar hides active editors when enabled, but this should only happen when a specific mode is selected.
VijitWadhwa
New Contributor III
Hi Jennifer,
Even if any specific mode was not selected, still the rectangle was not getting displayed. On setting the ` MyMapView.SketchEditor.IsVisible = true;` , I am able to see the rectangle, but the lines and polygons made by the measure toolbar get disappeared, How should i resolve it ?
Thanks
JenniferNery
Thanks for confirming. I just logged MeasureToolbar bug here. Not having any mode selected, should not have interfered with current SketchEditor.
However, the behavior where the measure draw feedback disappears once another SketchEditor becomes active is by design. MapView can only be assigned one SketchEditor at a given time.
If you don't want the other SketchEditor draw session to be canceled, you can disable it first and assign to MapView once your draw/edit session is over. You can do this by keeping reference to the current SketchEditor.
public MainWindow()
    InitializeComponent();
    _sketchEditor = MyMapView.SketchEditor;
    MyMapView.Map = new Map(Basemap.CreateTopographic());
private readonly SketchEditor _sketchEditor;
private async void OnDraw(object sender, RoutedEventArgs e)
    SketchEditor otherSketchEditor = null;
    if (MyMapView.SketchEditor != _sketchEditor)
        otherSketchEditor = MyMapView.SketchEditor;
        otherSketchEditor.IsVisible = false;
        otherSketchEditor.IsEnabled = false;
        MyMapView.SketchEditor = _sketchEditor;
    try
        var geometry = await MyMapView.SketchEditor.StartAsync(SketchCreationMode.Rectangle, false);
        var _ = MyMapView.SetViewpointAsync(new Viewpoint(geometry));
    catch (TaskCanceledException)
    catch (Exception ex)
        MessageBox.Show(ex.Message, ex.GetType().Name);
    if(otherSketchEditor != null)
        otherSketchEditor.IsVisible = true;
        otherSketchEditor.IsEnabled = true;
        MyMapView.SketchEditor = otherSketchEditor;
VijitWadhwa
New Contributor III
Thankyou for your help
JenniferNery
Outside SketchEditor, there already is built-in feature that allows you to zoom-in/out by rectangle. It looks like this and can be used in combination with key press. Shift to zoom-in, Shift+Ctrl to zoom-out.
GeoView.ViewpointChanged event will be raised and you can GetCurrentViewpoint then to add target geometry to your map.
If you wish to call SetViewpoint yourself like you are doing now and need the geometry result from rectangle sketch to remain on your map, you will need to add this to your GraphicsOverlay. You can use any symbol that matches the type of geometry. Rectangle will be a polygon so any fill symbol will do.
public MainWindow()
    MyMapView.GraphicsOverlays.Add(new GraphicsOverlay());
private async void OnTest(object sender, RoutedEventArgs e)
    try
        var overlay = MyMapView.GraphicsOverlays.FirstOrDefault();
        if (overlay == null)
            return;
        var symbol = new SimpleFillSymbol(SimpleFillSymbolStyle.Solid, Color.Transparent,
            new SimpleLineSymbol(SimpleLineSymbolStyle.Solid, Color.Red, 2));
        overlay.Graphics.Add(new Graphic(geometry, symbol));
