RasterLayer Alpha Channel?
967
10-20-2020 07:50 AM
artifact
Is there anyway to set an alpha channel for a rasterlayer renderer?
MichaelBranscomb
Esri Frequent Contributor
You could also try applying a mask e.g.
async Task AddRasterAndSetBackgroundColorValue()
    try
        // Create a raster dataset from a local file raster.
        Raster raster = new Raster(@"..\FileRaster.tif");
        // Await the Load to catch any errors.
        await raster.LoadAsync();
        // Create a raster function from the JSON string using the static/Shared method called: RasterFunction.FromJson(json as String)
        RasterFunction rasterFunction = RasterFunction.FromJson(jsonFunction);
        // Get the raster function arguments
        RasterFunctionArguments rasterFunctionArguments = rasterFunction.Arguments;
        // Get the list of raster names from the raster function arguments.
        IReadOnlyList<string> rasterNames = rasterFunctionArguments.GetRasterNames();
        // Set the local file raster as a raster name argument.
        rasterFunctionArguments.SetRaster(rasterNames[0], raster);
        // Create a new raster based on the raster function.
        Raster rasterWithFunction = new Raster(rasterFunction);
        // Create a new raster layer from the raster with function applied.
        RasterLayer rasterLayer = new RasterLayer(rasterWithFunction);
        // Add RasterLayer with function to Map OperationalLayers collection.
        Map.OperationalLayers.Add(rasterLayer);
    catch (Exception ex)
string jsonFunction =
    ""raster_function"":{""type"":""Mask_function""},
    ""raster_function_arguments"":
        ""nodata_values"":{""double_array"":[0],""type"":""Raster_function_variable""},
        ""nodata_interpretation"":{""nodata_interpretation"":""all"",""type"":""Raster_function_variable""},
        ""raster"":{""name"":""raster"",""is_raster"":true,""type"":""Raster_function_variable""},
        ""type"":""Raster_function_arguments""
    ""type"":""Raster_function_template""
Mike
artifact
or set a transparent background value?
artifact
MichaelBranscomb
    try
Mike
artifact
Hey Michael,
This is exactly what I ended up doing based on that link to a post you made back in 2019.
Cheers!
