Random AccessViolationException
6395
12
02-19-2015 10:42 AM
KeithMacIntyre
New Contributor III
This error occurs randomly, sometimes within a couple of hours of running the application, sometimes, over a day.  From the stack trace it appears to be coming from the Runtime.  The error occurs even when nothing is happening in our application
ntdll.dll!77ab73e6()
[Frames below may be incorrect and/or missing, no symbols loaded for ntdll.dll]
ntdll.dll!77a5863c()
ntdll.dll!77ab5e0d()
ntdll.dll!77a583d0()
ntdll.dll!77ab6612()
msvcr120.dll!0fd1ed63()
msvcr120.dll!0fd1ee1f()
RuntimeCoreNETDesktop.dll!05afe6f4()
RuntimeCoreNETDesktop.dll!05afe15a()
RuntimeCoreNETDesktop.dll!05afdd14()
RuntimeCoreNETDesktop.dll!05cdde4a()
RuntimeCoreNETDesktop.dll!05cd843e()
RuntimeCoreNETDesktop.dll!05cd7282()
RuntimeCoreNETDesktop.dll!05add73a()
RuntimeCoreNETDesktop.dll!05adca8d()
ntdll.dll!77a11354()
ntdll.dll!77ab5bca()
ntdll.dll!77ab6631()
user32.dll!762f791c()
user32.dll!762f7b7a()
user32.dll!762f7a7f()
user32.dll!762f97f4()
user32.dll!762f9859()
[External Code]
>xxx.exe!xxx.StartupWindow.Start() Line 575 + 0xe bytesC#
xxx.exe!xxx.StartupWindow.LoadScenario.AnonymousMethod__b() Line 540 + 0x8 bytesC#
[External Code]
mscoreei.dll!73baec94()
kernel32.dll!754c9820()
mscoree.dll!73c2bbcc()
kernel32.dll!754c919f()
ntdll.dll!77a2b5af()
ntdll.dll!77a2b57a()
And the best I could get was the disassembly where the error occurs.  The pointer was at 77AB73E6
77AB73BB  ja          77AB73BD
77AB73BD  add         byte ptr [eax],al
77AB73BF  add         byte ptr [ebx+esi*2-55h],cl
77AB73C3  ja          _RtlpValidateHeap@8+2Dh (77AB7421h)
77AB73C5  jae         _RtlDebugZeroHeap@8+0C1h (77AB7372h)
77AB73C7  ja          _RtlDebugZeroHeap@8+0A8h (77AB7359h)
77AB73C9  nop
77AB73CA  nop
77AB73CB  nop
77AB73CC  nop
_RtlpBreakPointHeap@4:
77AB73CD  mov         eax,dword ptr fs:[00000030h]
77AB73D3  cmp         byte ptr [eax+2],0
77AB73D7  je          _RtlpBreakPointHeap@4+21h (77AB73EEh)
77AB73D9  mov         byte ptr [_RtlpHeapInvalidBreakPoint (77AD1660h)],1
77AB73E0  mov         dword ptr [_RtlpHeapInvalidBadAddress (77AD1664h)],ecx
77AB73E6  int         3
77AB73E7  mov         byte ptr [_RtlpHeapInvalidBreakPoint (77AD1660h)],0
77AB73EE  ret
77AB73EF  nop
77AB73F0  nop
77AB73F1  nop
77AB73F2  nop
77AB73F3  nop
_RtlpValidateHeap@8:
77AB73F4  mov         edi,edi
77AB73F6  push        ebp
77AB73F7  mov         ebp,esp
77AB73F9  sub         esp,1Ch
77AB73FC  and         dword ptr [ebp-0Ch],0
77AB7400  and         dword ptr [ebp-4],0
77AB7404  push        ebx
77AB7405  push        esi
77AB7406  push        edi
77AB7407  mov         bl,dl
77AB7409  mov         edi,ecx
77AB740B  xor         dl,dl
77AB740D  mov         dword ptr [ebp-10h],edi
77AB7410  call        _RtlpValidateHeapHeaders@8 (77AB78C9h)
77AB7415  test        al,al
77AB7417  je          _RtlpValidateHeap@8+228h (77AB761Ch)
77AB741D  xor         eax,eax
77AB741F  inc         eax
77AB7420  test        bl,bl
77AB7422  jne         _RtlpValidateHeap@8+3Dh (77AB7431h)
77AB7424  test        dword ptr [edi+40h],20000000h
77AB742B  je          _RtlpValidateHeap@8+24Dh (77AB7641h)
77AB7431  and         dword ptr [ebp-14h],0
77AB7435  lea         ecx,[edi+0C0h]
77AB743B  mov         ebx,dword ptr [ecx]
77AB743D  and         dword ptr [ebp-1Ch],0
77AB7441  jmp         _RtlpValidateHeap@8+0B9h (77AB74ADh)
77AB7443  cmp         dword ptr [edi+4Ch],0
77AB7447  lea         esi,[ebx-8]
77AB744A  je          _RtlpValidateHeap@8+7Ah (77AB746Eh)
77AB744C  mov         eax,dword ptr [edi+50h]
77AB744F  xor         dword ptr [esi],eax
77AB7451  mov         al,byte ptr [esi+2]
77AB7454  xor         al,byte ptr [esi+1]
77AB7457  xor         al,byte ptr [esi]
77AB7459  cmp         byte ptr [esi+3],al
77AB745C  je          _RtlpValidateHeap@8+7Ah (77AB746Eh)
77AB745E  push        ecx
77AB745F  mov         edx,esi
77AB7461  mov         ecx,edi
77AB7463  call        _RtlpAnalyzeHeapFailure@12 (77AB81ADh)
77AB7468  lea         ecx,[edi+0C0h]
77AB746E  movzx       eax,word ptr [esi]
77AB7471  mov         ebx,dword ptr [ebx]
77AB7473  mov         dword ptr [ebp-8],eax
AsserSwelam1
Hi Keith,
Would you share what your app doing and which layers are you using? I tried to reproduce the issue with a Desktop app with just a base tiled layer and didn't see the error.
Asser
KeithMacIntyre
New Contributor III
I have been trying to reproduce it with a scaled down sample application without success.
It is happening in a scenario where I have one online layer:
World Imagery, ServiceUri="http://server.arcgisonline.com/ArcGIS/rest/services/World_Imagery/MapServer"
We have a military message layer with a few minefields and wire obstacles.
There are multiple graphics layers with basic polygon graphics, but a large number of them
There is a graphics layer that has many custom rendered symbols that we set the symbol image using SetSourceAsync(stream)
When it crashes, the application isn't doing anything at all.  I did notice when I had all exceptions turned on that I would occasionally get a WebException, so the runtime does seem to be accessing the internet even though the map extent hasn't changed.
KeithMacIntyre
New Contributor III
I am still unable to have it crash in my sample application, however, occasionally in our main application it doesn't happen either, although it does happen relatively often and on development and test machines.  I wonder if it would be worth generating a debug version of the runtime for us with the .pdb files (source code even better), and we may be able to better understand exactly what part is causing the problem since it's difficult to reproduce
AsserSwelam1
I have been trying to reproduce it too with no luck even with the app running overnight.
Sorry I don't think it would be possible to do what you ask for, It will be better to contact the support regarding this issue.
-Asser
AsserSwelam1
Keith, are you using .NET SDK 10.2.4 or 10.2.5 ? because if you using 10.2.4 you should try to see if the same issue happening with 10.2.5 or not, there is huge stability fixes added in 10.2.5.
Asser
JonDicken
New Contributor II
Hi, we are also seeing Access Violation Exceptions occurring in our application, and unfortunately they are crashing the entire application. We saw this in 10.2.4 and have also seen the same issue since moving to 10.2.5.
The issue seems to occur most frequently when adding/updating labels on larger feature layers - so we presume this is in some way related.
Looking at the crash dumps from our application we can see it is coming from the RuntimeCoreNETDesktop dll. Analyzing the exception using WinDBG gives us the following info & stack trace:
FAULTING_IP:
RuntimeCoreNETDesktop!AGRS_ValidateLicenseInfo+22c1a4
112b9d14 8b5e04          mov     ebx,dword ptr [esi+4]
EXCEPTION_RECORD:  ffffffff -- (.exr 0xffffffffffffffff)
ExceptionAddress: 112b9d14 (RuntimeCoreNETDesktop!AGRS_ValidateLicenseInfo+0x0022c1a4)
   ExceptionCode: c0000005 (Access violation)
  ExceptionFlags: 00000000
NumberParameters: 2
   Parameter[0]: 00000000
   Parameter[1]: 0000000c
Attempt to read from address 0000000c
STACK_TEXT:
WARNING: Stack unwind information not available. Following frames may be wrong.
19dcf988 112b7be5 2b291290 2409c454 2b291220 RuntimeCoreNETDesktop!AGRS_ValidateLicenseInfo+0x22c1a4
19dcf9e0 112b9c5f 00000046 2b291290 00000046 RuntimeCoreNETDesktop!AGRS_ValidateLicenseInfo+0x22a075
19dcf9f4 11797197 00000046 2b291290 2b827848 RuntimeCoreNETDesktop!AGRS_ValidateLicenseInfo+0x22c0ef
19dcfa30 11795def 1a4bf9b0 01291220 1a45f840 RuntimeCoreNETDesktop!AGRS_ValidateLicenseInfo+0x709627
19dcfa5c 11796b5c 2409c7a4 1a1eabe4 10a47bc0 RuntimeCoreNETDesktop!AGRS_ValidateLicenseInfo+0x70827f
19dcfc34 11798eb5 2409c18c 1a1ab0a8 19dcfc64 RuntimeCoreNETDesktop!AGRS_ValidateLicenseInfo+0x708fec
19dcfc70 11238a52 112bc2a7 2409c14c 1a1ab0a8 RuntimeCoreNETDesktop!AGRS_ValidateLicenseInfo+0x70b345
19dcfcbc 112bbd50 34209c00 2409c134 00000000 RuntimeCoreNETDesktop!AGRS_ValidateLicenseInfo+0x1aaee2
19dcfcf8 110955f7 2409c0d8 1a1f6b54 19dcfd30 RuntimeCoreNETDesktop!AGRS_ValidateLicenseInfo+0x22e1e0
19dcfd14 11810a8a 1a1ab0a8 2409c0f0 1a2a3f90 RuntimeCoreNETDesktop!AGRS_ValidateLicenseInfo+0x7a87
19dcfd3c 11810a37 1a2a3f90 1a1ce370 19dcfd5c RuntimeCoreNETDesktop!AGRS_ValidateLicenseInfo+0x782f1a
19dcfd4c 1159738e 1a2a3f90 1a3a64a8 19dcfdd0 RuntimeCoreNETDesktop!AGRS_ValidateLicenseInfo+0x782ec7
19dcfd5c 77919512 1a1ce370 4668941a 005611c8 RuntimeCoreNETDesktop!AGRS_ValidateLicenseInfo+0x50981e
19dcfdd0 77904429 1a1ce370 1a3a64a8 466896fa ntdll!RtlpTpWorkCallback+0x11d
19dcff30 7584338a 005611c0 19dcff7c 778e9f72 ntdll!TppWorkerThread+0x572
19dcff3c 778e9f72 005611c0 466896b6 00000000 kernel32!BaseThreadInitThunk+0xe
19dcff7c 778e9f45 77903e85 005611c0 00000000 ntdll!__RtlUserThreadStart+0x70
19dcff94 00000000 77903e85 005611c0 00000000 ntdll!_RtlUserThreadStart+0x1b
SYMBOL_STACK_INDEX:  0
SYMBOL_NAME:  runtimecorenetdesktop!AGRS_ValidateLicenseInfo+22c1a4
FOLLOWUP_NAME:  MachineOwner
MODULE_NAME: RuntimeCoreNETDesktop
IMAGE_NAME:  RuntimeCoreNETDesktop.dll
DEBUG_FLR_IMAGE_TIMESTAMP:  54bef6ac
STACK_COMMAND:  dt ntdll!LdrpLastDllInitializer BaseDllName ; dt ntdll!LdrpFailureData ; ~24s; .ecxr ; kb
FAILURE_BUCKET_ID:  NULL_CLASS_PTR_DEREFERENCE_c0000005_RuntimeCoreNETDesktop.dll!AGRS_ValidateLicenseInfo
The nature of the crash is obviously catastrophic for the rest of our application, and far from ideal.
Jon
KeithMacIntyre
New Contributor III
We are not using feature layers at all.  It looks like your crash is coming from the License check function.  That would be something that could be occurring when the application is doing nothing, like in our case.  Another thing we have in our application is a second small overview map on the same window.  Maybe having two mapview's in the same window could cause a problem?
RexHansen
We have seen this issue before, but reproducing it has been elusive.  Keith, you mentioned trying to create a sample app but were not able to repro.  If you guys are able to provide a sample app to reproduce at some point in the future, please share.
Thanks
-Rex
KeithMacIntyre
New Contributor III
I have not seen the Access Violation since we upgraded to 10.2.5, however, just this afternoon I have many times started receiving the following error and our application crashing:
Unhandled exception at 0x770a2f71 in xxx.WPF.exe: 0xC0020001: The string binding is invalid.
> KernelBase.dll!770a2f71()
  [Frames below may be incorrect and/or missing, no symbols loaded for KernelBase.dll]
  clr.dll!59d6b06b()
  clr.dll!59d6b06b()
  clr.dll!59e34ab9()
  clr.dll!59ab27fe()
  RuntimeCoreNETDesktop.dll!0f3d1c8a()
  RuntimeCoreNETDesktop.dll!0f3d0f9f()
  RuntimeCoreNETDesktop.dll!0f433371()
  msvcp120.dll!0556ef56()
