[POSSIBLE BUG] FeatureTable.CanAdd() lacks Feature argument
1212
11-24-2016 02:09 AM
PlamenIvanov1
New Contributor II
FeatureTable.CanAdd() lacks Feature argument - is this intentionally?
Note that FeatureTable.CanUpdate(feature) and FeatureTable.CanDelete(feature) have Feature argument. Note also that in Beta FeatureTable.CanAdd(feature) also had Feature argument.
Plamen
MichaelBranscomb
Esri Frequent Contributor
Thanks for the question. When reviewing the design post-beta, we decided CanAdd(feature) was unnecessary. It was essentially a convenience method which checks the service capabilities which are either true or false, regardless of the feature. Therefore the workflow is:
- Check FeatureTable.IsEditable
- Check FeatureTable.CanAdd()
- Create new Feature
- Call FeatureTable.AddFeatureAsync
- Handle the exception (if any)
Cheers
Mike
PlamenIvanov1
New Contributor II
Hi Mike,
Thanks for reply. But there is something unclear to me.
I agree that CanUpdate(feature) and CanDelete(feature) both should check specific cases, inapplicable to CanAdd() (for example - to be updated/deleted, a feature must already exists, which is not the case with adding new feature). But there are also checks applicable to both CanAdd() and CanUpdate(feature) equally:
- a feature with text field should be checked whether text value fits in field size;
- a feature should be checked for invalid values in an attribute (e.g. null value in NOT NULL field);
- a feature with unique field constraint should be checked whether constraint will not be violated by a feature field value;
- a feature should be checked whether it contains additional fields (added by code) not present in the FeatureTable
With these checks in mind in beta I realize following workflow (for update, but also for add):
- Create new Feature/Obtain Feature to edit
- Edit feature attributes/geometry
- Check FeatureTable.CanAdd(feature)/FeatureTable.CanUpdate(feature)
- Call FeatureTable.AddFeaturesAsync/FeatureTable.UpdateFeaturesAsync
Obviously now these checks cannot be performed prior to adding feature and catching exception - is this correct?. I am also curious - are these checks performed at CanUpdate(feature)?
Best Regards,
Plamen Ivanov
ESRI Bulgaria
