PictureMarkerSymbol moves with scene and altitude is 0
3065
08-13-2015 10:38 AM
JasonTrinidad1
New Contributor III
My code generates a points that has a PictureMarkerSymbol. It is run over and over, and the previously generated graphic is removed and a new one is added (so it looks like the plane is moving, does not have to be a fluent animation).  My issues is that I am able to add the initial heading of the symbol, so it has the correct heading, but the heading never changes afterwards. Also, when I rotate the map, the icon's heading seems to be fixed with the screen (always points to the same place with respect of the screen. Also, the altitude is always touching the ground.
(same point looked from another angle)
How do I make the direction of the icon always point to the real heading, and how can I have some elevation?
My code:
var graphicsOverlay = MySceneView.GraphicsOverlays["MyGraphicsOverlay"] as Esri.ArcGISRuntime.Controls.GraphicsOverlay;
if (graphicsOverlay == null)
    graphicsOverlay = new GraphicsOverlay();
    graphicsOverlay.ID = "MyGraphicsOverlay";
//Convert from latlon to ArcGis Window coordinate
var scenePoint =  new Esri.ArcGISRuntime.Geometry.MapPoint(lon,lat,alt,MySceneView.SpatialReference);
var pointSceneGraphic = new Esri.ArcGISRuntime.Layers.Graphic();
pointSceneGraphic.Geometry = scenePoint;
//set the graphic of the placemarker
Esri.ArcGISRuntime.Symbology.PictureMarkerSymbol imgSym = new Esri.ArcGISRuntime.Symbology.PictureMarkerSymbol();
imgSym.SetSourceAsync(new Uri(iconHref));
imgSym.AngleAlignment = Esri.ArcGISRuntime.Symbology.MarkerAngleAlignment.Map;
imgSym.Angle = platformHeading;
pointSceneGraphic.Symbol = imgSym;
ret = pointSceneGraphic.GetHashCode().ToString();
MySceneView.GraphicsOverlays[0].Graphics.Add(pointSceneGraphic);
foreach (var graphicsObj in graphicsOverlay.Graphics)
    if (graphicsObj.GetHashCode().ToString() == oldId)
        graphicsOverlay.Graphics.Remove(graphicsObj);
        break;
My WPF looks like this
<Grid>
        <esri:SceneView x:Name="MySceneView" Visibility="Visible" LayerLoaded="MySceneView_LayerLoaded">
            <esri:Scene>
                <esri:ArcGISTiledMapServiceLayer ID="BaseScene" ResamplingMode="None"
                    ServiceUri="http://services.arcgisonline.com/arcgis/rest/services/World_Imagery/MapServer" />
            </esri:Scene>
        </esri:SceneView>
</Grid>
Is there a better way to do what I'm doing?
AnttiKajanus1
Regular Contributor II
Here is example how to implement symbol rotation / height in Store app (just follow the same approach if you are working with wpf).
<Page
  x:Class="ArcGISRuntime.Samples.Store.Samples.SymbolRotation3d"
  xmlns="http://schemas.microsoft.com/winfx/2006/xaml/presentation"
  xmlns:x="http://schemas.microsoft.com/winfx/2006/xaml"
  xmlns:local="using:ArcGISRuntime.Samples.Store.Samples"
  xmlns:d="http://schemas.microsoft.com/expression/blend/2008"
  xmlns:mc="http://schemas.openxmlformats.org/markup-compatibility/2006"
  xmlns:esri="using:Esri.ArcGISRuntime.Controls"
  xmlns:layers="using:Esri.ArcGISRuntime.Layers"
  xmlns:symb="using:Esri.ArcGISRuntime.Symbology"
  xmlns:sceneSymb="using:Esri.ArcGISRuntime.Symbology.SceneSymbology"
  mc:Ignorable="d">
  <Grid>
  <Grid.Resources>
  <symb:SimpleRenderer x:Key="SimpleDiamondRenderer">
  <symb:SimpleRenderer.SceneProperties>
  <symb:RendererSceneProperties HeadingExpression="[Heading]"
   PitchExpression="[Pitch]"
   RollExpression="[Roll]" />
  </symb:SimpleRenderer.SceneProperties>
  <symb:SimpleRenderer.Symbol>
  <sceneSymb:DiamondMarkerSymbol Color="Blue" Width="1000" Height="2000"/>
  </symb:SimpleRenderer.Symbol>
  </symb:SimpleRenderer>
  <symb:SimpleRenderer x:Key="SimpleBoxRenderer">
  <sceneSymb:BoxMarkerSymbol Width="1000" Height="1000" Depth="1000" Color="Red"/>
  </Grid.Resources>
  <esri:SceneView x:Name="MySceneView" LayerLoaded="MySceneView_LayerLoaded">
  <esri:Scene>
  <esri:Scene.Surface>
  <esri:ServiceElevationSource ServiceUri="http://elevation3d.arcgis.com/arcgis/rest/services/WorldElevation3D/Terrain3D/ImageServer"
  IsEnabled="True" />
  </esri:Scene.Surface>
  <layers:ArcGISTiledMapServiceLayer ID="AGOLayer"
  <!--<layers:GraphicsLayer ID="DiamondGraphicsLayer" Renderer="{StaticResource SimpleDiamondRenderer}">
  <layers:GraphicsLayer.SceneProperties>
  <layers:LayerSceneProperties SurfacePlacement="Draped"/>
  </layers:GraphicsLayer.SceneProperties>
  </layers:GraphicsLayer>
  <layers:GraphicsLayer ID="BoxGraphicsLayer" Renderer="{StaticResource SimpleBoxRenderer}">
  </layers:GraphicsLayer>-->
  </esri:Scene>
  <esri:SceneView.GraphicsOverlays>
  <esri:GraphicsOverlay ID="DiamondGraphicsLayer" Renderer="{StaticResource SimpleDiamondRenderer}">
  <esri:GraphicsOverlay.SceneProperties>
  <layers:LayerSceneProperties SurfacePlacement="Relative"/>
  </esri:GraphicsOverlay.SceneProperties>
  </esri:GraphicsOverlay>
  <esri:GraphicsOverlay ID="BoxGraphicsLayer" Renderer="{StaticResource SimpleBoxRenderer}">
  </esri:SceneView.GraphicsOverlays>
  </esri:SceneView>
  <Grid HorizontalAlignment="Right" VerticalAlignment="Top" Margin="10" Width="100">
  <Border BorderBrush="Gray" BorderThickness="2" CornerRadius="4" Background="LightGray">
  <StackPanel>
  <StackPanel Background="Transparent" Margin="5">
  <TextBlock x:Name="txtHeading" Text="Heading" Foreground="Black"/>
  <Slider x:Name="HeadingSlider" Minimum="0" Maximum="360" ValueChanged="OnHeadingSliderChanged"/>
  </StackPanel>
  <TextBlock x:Name="txtPitch" Text="Pitch"  Foreground="Black"/>
  <Slider x:Name="PitchSlider" Minimum="0" Maximum="360" ValueChanged="OnPitchSliderChanged"/>
  </StackPanel>
  <TextBlock x:Name="txtRoll" Text="Roll"  Foreground="Black"/>
  <Slider x:Name="RollSlider" Minimum="0" Maximum="360" ValueChanged="OnRollSliderChanged"/>
  </StackPanel>
  </StackPanel>
  </Border>
  </Grid>
  </Grid>
</Page>
using Esri.ArcGISRuntime.Controls;
using Esri.ArcGISRuntime.Geometry;
using Esri.ArcGISRuntime.Layers;
using Esri.ArcGISRuntime.Symbology;
using Esri.ArcGISRuntime.Symbology.SceneSymbology;
using System;
using System.Linq;
using Windows.UI.Xaml.Controls;
using Windows.UI.Xaml.Controls.Primitives;
namespace ArcGISRuntime.Samples.Store.Samples
  public sealed partial class SymbolRotation3d : Page
  public SymbolRotation3d()
  this.InitializeComponent();
  private void MySceneView_LayerLoaded(object sender, Esri.ArcGISRuntime.Controls.LayerLoadedEventArgs e)
  if (e.LoadError == null && e.Layer.ID == "AGOLayer")
  MySceneView.SetViewAsync(new Camera(new MapPoint(-106.57, 39.01, 14614.24), 281.66, 74.47), new TimeSpan(0, 0, 3), true);
  AddGraphics();
  private void AddGraphics()
  Graphic graphic = new Graphic(new MapPoint(-106.981, 39.028, 6000, SpatialReferences.Wgs84));
  // Add a graphic to each graphics layer. It will use the renderer specified in the XAML to render the graphic.
  foreach (GraphicsOverlay gOverlay in MySceneView.GraphicsOverlays)
  gOverlay.Graphics.Add(graphic);
  /// <summary>
  /// Change the Heading of the graphics based on the slider values (0-360).
  /// </summary>
  private void OnHeadingSliderChanged(object sender, RangeBaseValueChangedEventArgs e)
  foreach (Graphic g in gOverlay.Graphics)
  g.Attributes["Heading"] = (sender as Slider).Value;
  // Display the slider Heading value
  txtHeading.Text = String.Format("Heading: {0:0.00}", (sender as Slider).Value.ToString());
  /// <summary>
  /// Change the Pitch of the graphics based on the slider values (0-360)
  /// </summary>
  private void OnPitchSliderChanged(object sender, RangeBaseValueChangedEventArgs e)
  g.Attributes["Pitch"] = (sender as Slider).Value;
  // Display the slider Pitch value
  txtPitch.Text = String.Format("Pitch: {0:0.00}", (sender as Slider).Value.ToString());
  /// <summary>
  /// Change the Roll of the graphics based on the slider values (0-360)
  /// </summary>
  private void OnRollSliderChanged(object sender, RangeBaseValueChangedEventArgs e)
  g.Attributes["Roll"] = (sender as Slider).Value;
  // Display the slider Roll value
  txtRoll.Text = String.Format("Roll: {0:0.00}", (sender as Slider).Value.ToString());
JasonTrinidad1
New Contributor III
Thanks. I'll try it out.
AnttiKajanus1
Also if you are using a plane picture in 3d, i would recommend to use ModelMarkerSymbol with 3d plane in instead of simple picture.
JasonTrinidad1
New Contributor III
I managed to get the elevation working, but the heading is still off. When I create the first graphics object, the heading is correct. This function is ran over and over, deleting the previous graphic, and adding a new one. All the new placemarks have the angle of the first placemark ever created. I also added MySceneView_CameraChanged to get the current rotation of the scene in order to correct the angle of the palcemark, but still nothing.
var graphicsOverlay = MySceneView.GraphicsOverlays["MyPlacemarkLayer"] as Esri.ArcGISRuntime.Controls.GraphicsOverlay;
Graphic graphic = new Graphic(new MapPoint(lon, lat, alt,MySceneView.SpatialReference));
imgSym.AngleAlignment = Esri.ArcGISRuntime.Symbology.MarkerAngleAlignment.Map; //Does this even do anything
imgSym.Angle = platformHeading + _mapRotation;
ret = graphic.GetHashCode().ToString();
graphic.Symbol = imgSym;
//graphic.Attributes["Heading"] = _mapRotation + _mapRotation; //This doesn't do anything
MySceneView.GraphicsOverlays["MyPlacemarkLayer"].Graphics.Add(graphic);
for (int i = 0; i < MySceneView.GraphicsOverlays["MyPlacemarkLayer"].Graphics.Count; i++)
    if (MySceneView.GraphicsOverlays["MyPlacemarkLayer"].Graphics.GetHashCode().ToString() == oldId)
        MySceneView.GraphicsOverlays["MyPlacemarkLayer"].Graphics.RemoveAt(i);
        break;
private void MySceneView_CameraChanged(object sender, EventArgs e)
        _mapRotation = MySceneView.GetCurrentViewpoint(ViewpointType.CenterAndScale).Rotation;
        canvasBox.RenderTransform = new RotateTransform(360 - _mapRotation, canvasBox.Width / 2, canvasBox.Height / 2);
                g.Attributes["Heading"] = (double)g.Attributes["Heading"] + _mapRotation;
In this example, I set my heading to be 45 and to increment by 5 every iteration. The placemark seems to get stuck at 45 forever.
This is my WPF
<Grid>
<Grid.Resources>
  <esri:SimpleRenderer x:Key="MyRenderer">
   <esri:SimpleRenderer.SceneProperties >
    <esri:RendererSceneProperties
   </esri:SimpleRenderer.SceneProperties>
   <esri:SimpleRenderer.Symbol>
    <esri:PictureMarkerSymbol AngleAlignment="Map" />
   </esri:SimpleRenderer.Symbol>
  </esri:SimpleRenderer>
</Grid.Resources>
<esri:SceneView x:Name="MySceneView" Visibility="Visible"  LayerLoaded="MySceneView_LayerLoaded" CameraChanged="MySceneView_CameraChanged" >
  <esri:Scene>
    <esri:ServiceElevationSource ServiceUri="http://elevation3d.arcgis.com/arcgis/rest/services/WorldElevation3D/Terrain3D/ImageServer"  IsEnabled="True" />
  </esri:Scene>
   <esri:GraphicsOverlay ID="MyPlacemarkLayer" Renderer="{StaticResource MyRenderer}" RenderingMode="Dynamic">
     <esri:LayerSceneProperties SurfacePlacement="Relative"/>
</esri:SceneView>
</Grid>
