Order of the layers
414
03-15-2019 06:32 AM
AlexVelez
Hi
I am using SDK .NEt 100.4 and i have a MMPK file created with the layers in a specific order, by example:
Layer 1
Layer 2
Layer 3
This is because i need to show the layers in that specific order and dont overlap , but when i load the package throught MobileMapPackage.OpenAsync(url) order is reversed:
Layer 3
Layer 2
Layer 1
How can I keep the original order?
Thanks!
dotMorten_esri
Esri Notable Contributor
Are you seeing the layers render in the wrong order? Note that when you inspect the layers in the package, you'll see the bottom-most one first, top-most last (ie in the order things render in). This is also the same order XAML renders things in. If this is for display-purposes in a layer-list, you can always use the .Reverse() method on the list to get a reversed list for your itemssource
