oAuth ClientId Problem with ArcGIS Enterprise Portal
798
05-04-2018 06:30 AM
PaulGiard
New Contributor III
I am working on a prototype with the following design:
Portal authenticates using Microsoft Azure with Multifactor Authentication and everything works fine.  I can login and Authenticate with multifactor authentication.
I am now trying to connect to Portal via the ArcGIS Runtime .NET.  I am following the code found in the online samples for oAuth.
The issue I am having is the OAuthClientInfo.ClientId does not seem to exists in Portal.  When I do not supply a ClientId the challenge dialog does not display.  When I enter a random ClientId the challenge dialog displays with the message invalid ClientId
Where does the ClientId come from in Portal?
PaulGiard
New Contributor III
Resolved.  By adding an application to the ArcGIS Enterprise Portal I have a ClientID to authenticate with.
PaulGiard
New Contributor III
