NotSupportedException when setting Graphic attributes api 100 under UWP
705
05-10-2017 11:52 AM
mh10
We have code that was running ok under api 10.2.7
but now under api 100 we are getting
System.NotSupportedException when ever we do anything with a graphic's attributes:
var Graphic = new Graphic(Point, new List<KeyValuePair<string, object>>()
    new KeyValuePair<string, object>("Mode", Mode),
or like this:
Graphic.Attributes.Add(new KeyValuePair<string, object>("Mode", Mode));
Is there any workaround for this?
mh10
Hi
I think it works if we only add string attributes? In the code above Mode is an object
dotMorten_esri
Esri Notable Contributor
Only simple value types are supported as attributes (ie string, integer, double, etc)
