Newby Needs Help in Creating an Offline c# Project
965
12-17-2017 03:25 PM
JohnManson1
Hi gang, I am an Access VBA developer, I would like to move my db over to .NET, and add GIS functionality.  I am new to c#, and xaml, but I'm willing to learn (my experiance has so far been with VB).  I have installed the esri runtime in visual studio, and have developed a sample ap (wpf) that displays an online map etc.  I have also setup a local arcGIS server on my local machine, and have created a .geodatabase with some local data for testing (two layers in there).  I have been trolling around the various esri pages and git looking for a sample c# (or VB) project that loads and displays data from a local server for offline use, but I can't find one - they are all online stuff.  I can find some code snippets etc, but I'm not very comfortable with c# syntax, so a comlete running ap sample would be better to start with if possible.  Can anyone help me?  Much appreciated.  -John
NathanCastle1
Hi John,
We've just shared a Local Server sample yesterday. You can find it in the WPF sample viewer or you can view the sample on GitHub
That sample reads a shapefile, but the changes needed to use a geodatabase should be minimal. I'll take a look at making a sample to demonstrate Local Server use with geodatabases specifically.
JohnManson2
New Contributor II
Thanks Nathan, I'll look at this tomorrow.
John
ShaharBukra
New Contributor III
Hi John,
in addition to what Nathan sends you i would more then recommend you to check this out
Inside the ArcGIS for Developers you have 2 Tabs that can help you.
  1. Browse ArcGIS DevLabs | ArcGIS for Developers
  2. Get Started with Example Apps | ArcGIS for Developers
Cheers,
Shahar.
JohnManson2
New Contributor II
Thanks Shahar, I'll look at this as well.  Didn't notice the labs in there.....
