MMPK with Basemap
1076
07-20-2017 12:26 PM
MarkCederholm
Occasional Contributor III
Here's an example of a mobile map package containing a map with a basemap layer.  If I use the map directly, or copy the operational plus basemap layers to a new map, it will not render and hangs up.  If I copy only the operational layers to a new map, the map will render.
JenniferNery
Hi Mark,
Thanks for reporting this issue. I'm able to reproduce the issue with released versions of the API v100.x. While I am not sure what is causing the basemap layers to fail during load, the issue appears fixed in our current version. I can find out for you if there's a workaround for this.
JenniferNery
Hi Mark,
MarkCederholm
If you can find a workaround, that's great, but it's not a huge issue for me.  Normally I only store operational layers in a mobile map package:  I was just playing around with base layers to see how they worked.
JenniferNery
Hi Mark,
According to the developer who worked on the fix, you can do the following for the meantime:
To avoid the problem user can:
  • Remove indexes for UUID fields
  • Use fields of string type instead of UUID, if it is possible.
MarkCederholm
Thanks for the info!
