.mmpk displayed in v100 UWP App shows a) different symbology and b) different layer scale ranges compared to both ArcGIS Pro and .geodatabase created in ArcMap (Create Runtime Content GP tool)
860
04-11-2017 05:54 AM
deleted-user-Ohz6rwd1kavx
We are wondering if others are seeing this behavior/issue, whether or not this is a known issue in v100, if there are workarounds, and when fix is planned...
We are seeing an issue where a v100 UWP map initialized from Mobile Map Package (mmpk) has a) different symbology and b) different layer scale ranges compared to both ArcGIS Pro and .geodatabase created in ArcMap (Create Runtime Content GP tool). The .geodatabase shows the 'Expected' symbology and scale ranges.
Problem 1: underground structure layer -> junction box should appear as green rectangles on map.
  • When we use mmpk, these features are not showing at all in the app (Figure 1).
  • When we use .geodatabase (Figure 2), features are symbolized as green rectangles as expected (same as Pro).
Figure 1
Figure 2
Problem 2: support structures --> poles : this layer should have scale dependency.
  • When we use mmpk, the data draw at all scales (Figure 3).
  • When we use straight .geodatabase, layer scale dependency behaves as expected (Figure 4), turning these data off when zoomed out beyond threshold scale. This is same as in Pro.
Figure 3
Figure 4
