Memory leak when adding feature layers to my map
4307
8
08-31-2015 08:47 AM
MattMiley
Whenever navigating between pages from a page that contains a map with 3 feature layers the application freezes without any exceptions.
I've set NavigationCacheMode = NavigationCacheMode.Disabled; at all my xaml pages but its still crashing all the time. Is there anything i can do?
AnttiKajanus1
Occasional Contributor III
Hi Matt,
I had time to check this today. So the freeze comes when navigating away from the map page? I don't see the freeze with current build so it should be fixed in 10.2.7 release.
MattMiley
I think i found my mistake. I was building my maps at each page from scratch in all of my view models, this was causing the memory issues.
I moved the map the the App.xaml resources and just did it all in xaml and binded to it and performance improved greatly.
MattMiley
Nevermind it still crashes nonstop when there's more than 3 feature layer.. Sucks
AnttiKajanus1
Can you create a simple reproducer for this issue?
MattMiley
Some of my feature layers have labels that are defined from the service, maybe its the labeling issue from this post.. Application freezes without exception
MichaelBranscomb
Esri Frequent Contributor
Hi Matt,
We are investigating - thanks for the reproducer app.
Cheers
Mike
MattMiley
Any updates on this? I got people bugging me about it..
MattMiley
Still no updates with this. So this pretty much means AGOL hosted feature layers are useless.
Thanks guys!
AnttiKajanus1
Hi Matt,
