LocalMapService load .mpk map fail
4177
12
07-05-2015 08:39 PM
坤王
map don't load mpk map. debug it only execute  await localMapService.StartAsync();  why?
code:
public async void CreateLocalServiceAndDynamicLayer()
            try
                LocalMapService localMapService = new LocalMapService(@"maps\water-distribution-network.mpk");
                ArcGISDynamicMapServiceLayer arcGISDynamicMapServiceLayer = new ArcGISDynamicMapServiceLayer()
                    ID = "arcGISDynamicMapServiceLayer",
                    ServiceUri = localMapService.UrlMapService,
                MyMapView.Map.Layers.Add(arcGISDynamicMapServiceLayer);
            catch (Exception ex)
                MessageBox.Show(ex.Message);
SachinKanaujia
Occasional Contributor III
What is the exception message that you are getting?
Generally you will not have to start the service Async if you are already adding it to JMap.
Have you tried with the sample mpks that ESRI provides, to know if its a problem with only the mpk you are using? Is it possible for you to share the MPK?
坤王
it don't have exception message. Through the breakpoint debuging,it only perform to  "await localMapService.StartAsync();  "
I give my friend use the project,he can show the map,But i don't.
what is JMap?
mpk download:
https://github.com/Esri/arcgis-runtime-samples-data/tree/master/maps
MichaelBranscomb
Esri Frequent Contributor
If the awaited call to LocalMapService.StartAsync returns then the service is starting successfully. This would suggest it could be an issue with the map extent not zoomed to the correct area (that water distribution mpk is a very small sample area)?
Cheers
Mike
坤王
Yes,mpk is a very small sample area.How to solve this problem?
MichaelBranscomb
Do you see anything at all? An esri logo? A gray background grid?
Checking the sample, although it does not explicitly zoom to the extent of the ArcGISDynamicMapServiceLayer, that layer is the only one in the map and the MapView should automatically display. You could add the following lines of code which should force the MapView extent to that of the service. Or you may catch an exception if there is a problem initializing the layer:
await arcGISDynamicMapServiceLayer.InitializeAsync();
await MyMapView.SetViewAsync(new Viewpoint(arcGISDynamicMapServiceLayer.FullExtent));
Additionally, I note that sample does not handle the LayerLoaded event on the MapView. You do this by registering an event handler e.g.
MyMapView.LayerLoaded += MyMapView_LayerLoaded;
And then handling the event:
private void MyMapView_LayerLoaded(object sender, LayerLoadedEventArgs e)
  if (e.LoadError != null)
    MessageBox.Show(e.LoadError.Message, "Layer Error");
    return;
Or alternatively use the MapView.LayersLoadedAsync awaitable task and check the LayerLoadedResult objects.
Cheers
Mike
坤王
I can see an esri logo,not see a gray background grid.
my code:
using Esri.ArcGISRuntime.Controls;
using Esri.ArcGISRuntime.Layers;
using Esri.ArcGISRuntime.LocalServices;
using System;
using System.Threading.Tasks;
using System.Windows;
using System.Windows.Controls;
namespace NavMapAPP
    public partial class MainWindow : Window
        public MainWindow()
            InitializeComponent();
            CreateLocalServiceAndDynamicLayer();
                return;
            try
run screenshot: program don't show "layer error".
nakulmanocha
If it breaks on the following line then please confirm if the mpk is supported for runtime.
If it get passed the above line without throwing any exception then please follow the suggestions which Mike provided in his last reply.
If your mpk isn't too big would you mind attaching it here?
坤王
nakulmanocha
As you see above I had no issues loading your mpk. Sorry didn't get chance to reply sooner.
