Label Priority (JSON) not working
3051
8
01-20-2021 04:24 AM
GonzaloMuöoz
I'm using the Label's Priority of the JSON in order to priorise between differente GraphicsOverlay but it's not working. Is it a known bug? I'm using it this way:
StringBuilder labelBuilder = new StringBuilder();
labelBuilder.AppendLine("{");
// Define a labeling expression that will show the Name attribute value
labelBuilder.AppendLine("\"allowOverrun\": true ,");
labelBuilder.AppendLine("\"allowOverlapOfLabel\": \"allow\" ,");
labelBuilder.AppendLine("\"allowOverlapOfFeatureBoundary\": \"allow\" ,");
labelBuilder.AppendLine("\"allowOverlapOfFeatureInterior\": \"allow\" ,");
labelBuilder.AppendLine("\"priority\": 25 ,");
labelBuilder.AppendLine("\"labelExpressionInfo\": {");
labelBuilder.AppendLine("\"expression\": \"return $feature.Name;\"},");
// Align label horizontally
labelBuilder.AppendLine("\"labelPlacement\": \"esriServerPointLabelPlacementCenterRight\",");
labelBuilder.AppendLine("\"multiPart\": \"labelLargest\",");
// Set the style for the text symbol
labelBuilder.AppendLine("\"symbol\": {");
labelBuilder.AppendLine("\"color\": [255,255,255,255],");
labelBuilder.AppendLine("\"haloColor\": [51,51,51,255],");
labelBuilder.AppendLine("\"haloSize\": 1.5,");
labelBuilder.AppendLine("\"font\": {\"size\": 10, \"weight\": \"bold\"},");
labelBuilder.AppendLine("\"type\": \"esriTS\"}");
labelBuilder.AppendLine("}");
Thanks
dotMorten_esri
Esri Notable Contributor
What are the label expressions you use on each graphics overlay? How are you assigning them to the overlays?
GonzaloMuöoz
HI Morten,
for low priority graphicsoverlay I use the one on my initial comment. For high priority graphicsoverlay I use the following:
labelBuilder.AppendLine("\"priority\": 0,");
labelBuilder.AppendLine("\"offsetDistance\": \"-10\",");
Then I add them to each graphics overlay depending on the priority by adding them to the LabelDefinitions object of them:
LabelDefinitions.Add(LabelDefinition.FromJson(JsonCode));
Being JsonCode a string with the definition of the label (the one attached up)
Thanks,REgards
PeterDimitrov1
Hi GonzaloMuöoz,
Can you confirm if you are seeing this in 2D or 3D?
Thanks
GonzaloMuöoz
Hi PeterDimitrov1,
2D.
Thanks
PeterDimitrov1
I noticed that in both of your label definitions you set the property "allow label overlap" to allow.
This will allow labels to overlap and will fully disregard any label deconfliction, producing the results you see / priority being ignored.
If you set "allow overlap of label" to "exclude", this will prevent labels from overlapping and you will see correct behaviour.
Following from the above information ,it is also worth to note that the default deconfliction strategy applied to labels is static, unless specified otherwise.
In the case where overlap of labels is not allowed, static deconfliction would mean that the lower priority label will not be drawn / removed in order to prioritize anything with higher priority. You can also try dynamic deconfliction, and simply put, labels will try to "move out of the way".
Static deconfliction, no overlap:
Dynamic deconfliction, no overlap:
Useful info on deconfliction and other JSON properties here: https://developers.arcgis.com/net/wpf/guide/json-label-class-properties.htm
Thanks.
GonzaloMuöoz
Thanks for the answer.
Our client wants exactly that, show all the labels even if they overlap but give them priority of visibility based on the graphicsoverlay it belongs. I suppose that this is not possible right now, will this functionality be available in the future?
Regards.Gonzalo
PeterDimitrov1
Hi Gonzalo,
This is not something that we support at the moment. I have raised your idea with my team as a potential enhancement to our product for future releases, however your case will be made stronger if it also went through the official channels.
We have a forum ideas panel , which you can find here - https://community.esri.com/t5/custom/page/page-id/arcgis-ideas#custom-tiled-node-navigation
Kind Regards,
Peter Dimitrov
MichaelBranscomb
Esri Frequent Contributor
Thanks for your feedback on this issue. Support for showing all labels regardless of overlap, and accounting for label class priority in the 2D map view was added in version 100.12.
Thanks
