Label don't show After Define LabelDefinition for ArcGISMapImageSublayer
1905
10
07-24-2017 06:29 PM
xiaoguangyan
Hi, I Define LabelDefinition for ArcGISMapImageSublayer after the ArcGISMapImagelayer loaded, but the labels don't show, the field is to be labeld is "name"
private async void ArcGISMapImageLayer_LoadStatusChanged(object sender, LoadStatusEventArgs e)
var lyr = sender as ArcGISMapImageLayer;
if (e.Status == LoadStatus.Loaded)
var subLyr = lyr.Sublayers[1] as ArcGISMapImageSublayer;
await subLyr.LoadAsync();
subLyr.LabelDefinitions.Add(LabelDefinition.FromJson("{\"labelExpression\": \"[name]\",\"labelPlacement\": \"esriServerPolygonPlacementAlwaysHorizontal\",\"symbol\": {\"color\": [255,0,255,123],\"font\": {\"size\": 16},\"type\": \"esriTS\"}}"));
NagmaYasmin
Hi Yan,
Since you are using ArcGISMapImageLayer, you need to define the label expression in json format. Please see the documentation link :
"Labels for map image sublayers (ArcGISMapImageLayer) can be defined in much the same way as labels for feature layers and graphics overlays. The main difference is that labels for map image layers are rendered by the server and not in your client app. You must therefore use ArcGIS Server REST API syntax to define your label expressions, rather than the Arcade syntax you can use with feature layers and graphics overlays."
Label map features—ArcGIS Runtime SDK for .NET (WPF) | ArcGIS for Developers
Hope that helps
Nagma
xiaoguangyan
Hi Nagma
I have noticed that the difference between map image layers and feature layer, I use the  ArcGIS Server REST API syntax to define my Json, but labels still don't show
JenniferNery
I tried your label JSON and it seems valid. Does 'name' attribute exist on the service? You also might be missing LabelsEnabled=true.
I updated the JSON a bit to fit the service in this sample.
            MyMapView.Map = new Map(Basemap.CreateTopographic());
            var layer = new ArcGISMapImageLayer(new Uri("http://sampleserver6.arcgisonline.com/arcgis/rest/services/USA/MapServer"));
            layer.Loaded += (s, e) =>
                  var subLayer = (ArcGISMapImageSublayer)layer.Sublayers[2];
                  subLayer.LabelsEnabled = true;
                  subLayer.LabelDefinitions.Add(LabelDefinition.FromJson(("{\"labelExpression\": \"[state_name]\",\"labelPlacement\": \"esriServerPolygonPlacementAlwaysHorizontal\",\"symbol\": {\"color\": [255,0,255,123],\"font\": {\"size\": 16},\"type\": \"esriTS\"}}")));
            MyMapView.Map.OperationalLayers.Add(layer);
xiaoguangyan
Hi Jennifer
I have set LabelsEnabled=true, but I noticed that the service you test http://sampleserver6.arcgisonline.com/arcgis/rest/services/USA/MapServer/2 the "Can Modify Layer: true" , but mine is false, and I try another service with Can Modify Layer: false, the labels will don't show all the same. So I doubt that if the Can Modify Layer: true is necessary for LabelDefination of ArcGISMapImageSubLayer?
MichaelBranscomb
Esri Frequent Contributor
Yes, that's correct - your service must allow per layer modification, exposed in the capabilities as "Can Modify Layer" / "canModifyLayer".
The modification of ArcGISMapImageSublayers uses the DynamicLayer capability of the MapServer endpoint - for more info see ArcGIS REST API
Cheers
Mike
xiaoguangyan
Hi
I use the ArcGISmapimagelayer with Can Modify Layer=True , but the labels show in messy code like pic below
NagmaYasmin
Hi Yan,
I believe you are trying to display the labels in Chinese characters. If that is the case, labels displayed in Chinese language isn't supported yet, that's my understanding.
Best,
Nagma
xiaoguangyan
Hi, Nagma
I do want to display the labels in Chinese characters, I am sorry to hear that labels displayed in Chinese language isn't supported yet.
HTKSHI
font tag set font_family which support Chinese characters
e.g:
"{\"labelExpression\": \"[state_name]\",\"labelPlacement\": \"esriServerPolygonPlacementAlwaysHorizontal\",\"symbol\": {\"color\": [255,0,255,123],\"font\": {\"size\": 16,\"family\":\"Microsoft YaHei\"},\"type\": \"esriTS\"}}"
