KML string to KmlLayer
2367
08-04-2015 07:20 AM
JasonTrinidad1
New Contributor III
I've seen that similar questions have been asked, bust most of them are over a year old. Is there a way to add a KmlLayer from a KML string or a local file?
I tried the following, but it only works when file is a url.
string file = @"C:\devel\test.kml";
KmlLayer kmlLayer = new KmlLayer(new Uri(file));
MyMapView.Map.Layers.Add(kmlLayer);
JasonTrinidad1
New Contributor III
For anyone interested, I was able to make it work by adding the KML layer with
MyMap.Layers.Add(kmlLayer);
instead of
I wasn't able to do it with a string, but a file is good enough.
KennethLathan
New Contributor II
Jason,
I think it only takes a URI, you have to convert it no matter what the source is. Here's their official example of dragging and dropping a local file to the Map, and it looks like they did the same thing you did:
private async void MyMapView_Drop(object sender, DragEventArgs e)
     if (e.Data.GetDataPresent(DataFormats.FileDrop))
          string[] files = (string[])e.Data.GetData(DataFormats.FileDrop);
          KmlLayer kmlLayer = new KmlLayer(new Uri(files[0]));
          await kmlLayer.InitializeAsync();
          //Add the kml layer
          //Zoom to the kml layer if available
          if (kmlLayer.RootFeature.Viewpoint != null)
               await MyMapView.SetViewAsync(kmlLayer.RootFeature.Viewpoint);
Hope this helps.
JasonTrinidad1
New Contributor III
instead of
