Is there a simple way to determine which barriers were routed around in RouteTask?
680
06-13-2017 06:59 PM
ClayGinn
I need to be able to determine if the barriers which were passed in through RouteParameters were utilized. Is there a simple way to return this information, or is it not tracked by RouteTask?
NagmaYasmin
Hi Clay,
RouteTask.SolveRouteAsync() returns the Task<RouteResult>
If you have a point barrier, you need to set RouteParams.ReturnPointBarriers to true to get the barrier information from the RouteResult.
RouteParams.ReturnPointBarriers = true; // PointBarriers
var routeResult = await RouteTask.SolveRouteAsync(RouteParameters)
Hope that helps.
Nagma
