Is MPKX supported by the ArcGIS Runtime
2152
06-13-2018 11:09 AM
deleted-user-Qwv0Lt2wZ0Zu
Hello!
The documentation in ArcGIS Pro states that it is possible to select an option for the MPKX map package that will make it accessible to the ArcGIS Runtime (.NET). However, I have not been able to find any reference in the ArcGIS Runtime for .NET help that identifies the class that supports opening up this package type.
Package Map—Data Management toolbox | ArcGIS Desktop
Is this packaged file type truly supported by ArcGIS Runtime for .NET? And if so, how do I open it?
Thanks!
Jen
MichaelBranscomb
Esri Frequent Contributor
In the upcoming v100.3 release we are planning to add support for .mpkx files when used in conjunction with the ArcGIS Runtime Local Server - for an explanation of how this works in the current v100.2 release with .mpk files from ArcMap see Local Server—ArcGIS Runtime SDK for .NET (WPF) | ArcGIS for Developers.
To work with packages from ArcGIS Pro directly in ArcGIS Runtime you should look at the Mobile Map Package (.mmpk) see:
Mobile map package—ArcGIS Pro | ArcGIS Desktop
Maps (2D)—ArcGIS Runtime SDK for .NET (WPF) | ArcGIS for Developers
Create an offline map—ArcGIS Runtime SDK for .NET (WPF) | ArcGIS for Developers
Cheers
Mike
Hi Michael,
Thanks very much for the additional info on this!
Jen
