Is it possible to run geoprocessing tasks using python scripts
619
08-16-2017 08:50 AM
ManelKEDDAR
Hello ,
i need to know if it's possible to run a script python for making processing tasks using the runtime v 100.1 ?  it's new for me and i don't know how to do it ? i cheked   https://developers.arcgis.com/net/latest/wpf/guide/geoprocessing.htm here and i found that it's possible to use Script tools that run a geoprocessing Python script file , i need examples how it works ? is it possible to use arcPy ?
thanks
MichaelBranscomb
Esri Frequent Contributor
Yes, it is possible to run Python scripts with ArcGIS Runtime SDK for .NET. It requires the use of the ArcGIS Runtime Local Server component.
For information on using the ArcGIS Runtime Local Server component see: Local Server—ArcGIS Runtime SDK for .NET (WPF) | ArcGIS for Developers
To create a LocalGeoprocessingService instance, you need to package your Python script as a Geoprocessing Package (.gpk) including support for ArcGIS Runtime. More information here: A quick tour of geoprocessing packages—ArcMap | ArcGIS Desktop
Use of ArcGIS Runtime Local Server requires licensing at the Standard level: License your app—ArcGIS Runtime SDK for .NET (WPF) | ArcGIS for Developers
Cheers
Mike
ManelKEDDAR
Hello thanks for your answer i need more details about how to licence my app ?? still not clear on the doc ? thanks
ManelKEDDAR
Actually it's new for me , i didn't do that before , and I've seen the notion of credits that i don't understand its concept
thanks
