Ignore GeoViewTapped when zooming via Double tap (v100.2)
1099
02-14-2018 01:20 PM
ChrisSmith12
I'm using the GeoViewTapped event on MapView to show callouts for various objects. I would like to still support double click to zoom, however, when the user double taps my GeoViewTapped event fires causing callouts to be shown. Is there a way to disable or ignore GeoViewTapped events when the user double clicks on the map? Thank you.
MaraStoica4
Hi Chris,
There's a good example of what you're wanting to do in our Offline Mapbook example app. Hope this helps!
https://github.com/Esri/mapbook-wpf
Mara
ChrisSmith12
Thanks for your help Mara.
dotMorten_esri
Esri Notable Contributor
You're getting into an issue with gesture overlap. Basically you're using the same gesture for two things, and that's not going to go too well as you've found .
The only workaround you can really do here is to not act on the tapped event for a little while. If no double tapped event occurs, you move forward, but the downside there is the action will seem a little slower than it really is.
Alternatively I'd suggest you consider other gestures like right-click, ctrl+click, enable a tool etc to avoid the gesture overlap.
ChrisSmith12
Thanks Morten
