How to use geopackage (.gpk) created by Arcmap to use a service ?
1944
7
10-23-2018 11:34 PM
VijitWadhwa
New Contributor III
Hi , I created a .gpk file from ArcMap to use it in runtime. But after starting the local server , as soon as I start the LocalGeoprocessingService, I get an exception as follows
!message:socexit:{"error":"Worker process 'contour_host' exited while attempting to service request (attempt 1 of 1): endpoint='admin' headers={} params={asynchronous=, filePath=e:\\dlrl for kolkata 2\\feature to json\\contour.gpk, jobDir=C:\\Users\\Vijit Wadhwa\\AppData\\Local\\Temp\\arcgisruntime_3828\\contour\\jobs, maxRecords=1000, name=contour, outputDir=C:\\Users\\Vijit Wadhwa\\AppData\\Local\\Temp\\arcgisruntime_3828\\contour, type=GPServer, virtualDir=http://127.0.0.1:50000/q3HDdY/outputdir/contour} res='create' post=0 Crash dump path=C:\\Users\\Vijit Wadhwa\\AppData\\Local\\Temp\\ArcGISRuntimeErrorReports\\arcgisruntime_100.3.0.2102_service_20181024_110823.dmp","name":"contour","processId":-1}
Exception thrown: 'Esri.ArcGISRuntime.Http.ArcGISWebException' in mscorlib.dll
at Esri.ArcGISRuntime.LocalServices.LocalService.<StartServiceInternal>d__25.MoveNext()
--- End of stack trace from previous location where exception was thrown ---
at System.Runtime.CompilerServices.TaskAwaiter.ThrowForNonSuccess(Task task)
at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification(Task task)
at System.Runtime.CompilerServices.TaskAwaiter.GetResult()
at Geoprocessing.MainWindow.<ServerStatusChanged>d__3.MoveNext()
Can anyone please tell me, what I am doing wrong ?? and how should I resolve this issue ?
Thanks in advance
MichaelBranscomb
Esri Frequent Contributor
Try setting the ArcGISRuntimeEnvironment.TempPath Property to a much shorter path e.g. `E:\Temp`.
Cheers
Mike
VijitWadhwa
New Contributor III
I tried setting the  ArcGISRuntimeEnvironment.TempPath Property to a much shorter path , but I recieve same exception again ?
The same code sample works fine in Java. Please help ?
Thanks
Vijit
VijitWadhwa
New Contributor III
Hi Michael,
 I am facing this problem from last one month and I am stuck and unable to develop. Please provide some solution as soon as possible.
MichaelBranscomb
What options do you have enabled in your deployment file? (Local Server—ArcGIS Runtime SDK for .NET | ArcGIS for Developers )
Cheers
Mike
VijitWadhwa
New Contributor III
HI,
I have kept my deployment file as default , without making any changes. This is how it looks.
<?xml version="1.0" encoding="utf-8"?>
<!--ArcGIS Local Server Deployment Configuration-->
<Packages>
<!--This local server has support for ArcGIS Pro mpkx and gpkx packages. It is 64 bit only-->
<Package id="Pro" name="ArcGIS Pro Compatible Server" enabled="false">
<ChildPackages>
<!--Including Microsoft C and C++ libraries in the runtime deployment allows for XCopy style deployments.
Only include these if your setup is not installing the Microsoft redistribution package.-->
<Package id="ProCRuntime" name="Microsoft C and C++ Runtime Libraries" enabled="false" />
<!--Provides the ability to perform geoprocessing tasks via geoprocessing packages.-->
<!--Geoprocessing packages must be created with ArcGIS Runtime support enabled.-->
<Package id="ProGeoProcessing" name="Geoprocessing" enabled="false">
<ChildPackages>
<!--Adds 3D Analyst geoprocessing tools.-->
<Package id="Pro3DAnalyst" name="3D Analyst" enabled="false" />
<!--Provides the ability to use ArcGIS Locators-->
<Package id="ProGeoCoding" name="Geocoding" enabled="false" />
<!--Adds data consolidation, map packaging and create runtime content tools.-->
<Package id="ProMapPackaging" name="Map Packaging" enabled="false" />
<!--Adds the ability to produce results as Map Services.-->
<Package id="ProMapServerResults" name="Map Server Results" enabled="false" />
<!--Adds Network Analyst geoprocessing tools.-->
<Package id="ProNetworkAnalyst" name="Network Analyst" enabled="false" />
<!--Adds Spatial Analyst geoprocessing tools.-->
<Package id="ProSpatialAnalyst" name="Spatial Analyst" enabled="false" />
</ChildPackages>
</Package>
<!--Provides the ability to use Python scripts.-->
<Package id="ProPythonScripting" name="Python Scripting" enabled="false" />
<!--Provides additional vector and raster data format support.-->
<Package id="ProAdditionalDataFormats" name="Additional Data Formats" enabled="false">
<ChildPackages>
<!--Provides additional raster file data format support.-->
<Package id="ProRaster" name="Raster" enabled="false">
<ChildPackages>
<!--Provides support for ECW format Raster.-->
<Package id="ProECWRasters" name="ECW Rasters" enabled="false" />
<!--Provides support for Raster Mosaic Layers.-->
<Package id="ProMosaicRasters" name="Mosaic Rasters" enabled="false" />
</ChildPackages>
</Package>
<!--Provides additional vector file data format support.-->
<Package id="ProVector" name="Vector" enabled="false" />
<!--Adds support for direct connect to DBMS system that Esri supports. This option must be selected in conjunction with at least one of the following DBMS(s): DB2, Informix, Oracle, PostgreSQL, SQL Server, Netezza, HANA, Teradata or Alitbase.-->
<!--SDE direct connect deployed. Specific database drivers also required.-->
<Package id="ProSDE" name="SDE" enabled="false">
<ChildPackages>
<!--Adds support for direct connect to geodatabases stored in Alitbase.-->
<!--Alitbase Drivers must be present on end users machine.-->
<Package id="ProAlitbase" name="Alitbase" enabled="false" />
<!--Adds support for direct connect to geodatabases stored in Dameng.-->
<!--Dameng Drivers must be present on end users machine.-->
<Package id="ProDameng" name="Dameng" enabled="false" />
<!--Adds support for direct connect to geodatabases stored in DB2.-->
<!--DB2 Drivers must be present on end users machine.-->
<Package id="ProDB2" name="DB2" enabled="false" />
<!--Adds support for direct connect to geodatabases stored in Netezza.-->
<!--Netezza Drivers must be present on end users machine.-->
<Package id="ProNetezza" name="Netezza" enabled="false" />
<!-- Adds support for direct connect to geodatabases stored in Oracle.-->
<!--Oracle Drivers must be present on end users machine.-->
<Package id="ProOracle" name="Oracle" enabled="false" />
<!--Adds support for direct connect to geodatabases stored in PostgreSQL.-->
<!--PostgreSQL Drivers must be present on end users machine.-->
<Package id="ProPostgreSQL" name="PostgreSQL" enabled="false" />
<!--Adds support for direct connect to geodatabases stored in SAP HANA.-->
<!--SAP HANA SQL Server Drivers must be present on end users machine.-->
<Package id="ProSAPHANA" name="SAP HANA" enabled="false" />
<!--Adds support for direct connect to geodatabases stored in SQL Server.-->
<!--MS SQL Server Drivers must be present on end users machine.-->
<Package id="ProSQLServer" name="SQL Server" enabled="false" />
<Package id="ProSQLite" name="SQLite" enabled="false">
<ChildPackages>
<!--Adds support for SpatiaLite geometry type-->
<Package id="ProSpatialLite" name="SpatiaLite" enabled="false" />
</ChildPackages>
</Package>
<!--Adds support for direct connect to geodatabases stored in Teradata.-->
<!--Teradata Drivers must be present on end users machine.-->
<Package id="ProTeradata" name="Teradata" enabled="false" />
</ChildPackages>
</Package>
</ChildPackages>
</Package>
<!--Adds more projections and geotransformations.-->
<Package id="ProAdditionalProjectionEngineTransformations" name="Additional Projection Engine Transformations" enabled="false" />
<!--Enables debugging options within the runtime.-->
<!--Debugging options should only be used for testing purposes, and not deployed in final solutions.-->
<Package id="ProDebug" name="Debug" enabled="false">
<ChildPackages>
<!--Adds support for runtime logging.-->
<Package id="ProLogging" name="Logging" enabled="false" />
</ChildPackages>
</Package>
</ChildPackages>
</Package>
<!--This local server has support for ArcMap mpk and gpk packages.-->
<Package id="ArcMap" name="ArcMap Compatible Server" enabled="true">
<ChildPackages>
<Package id="ArcMapCRuntime" name="Microsoft C and C++ Runtime Libraries" enabled="false" />
<Package id="ArcMapGeoprocessing" name="Geoprocessing" enabled="true">
<ChildPackages>
<Package id="ArcMap3DAnalyst" name="3D Analyst" enabled="false" />
<Package id="ArcMapGeocoding" name="Geocoding" enabled="false" />
<Package id="ArcMapMapPackaging" name="Map Packaging" enabled="true" />
<Package id="ArcMapMapServerResults" name="Map Server Results" enabled="false" />
<Package id="ArcMapNetworkAnalyst" name="Network Analyst" enabled="false" />
<Package id="ArcMapSpatialAnalyst" name="Spatial Analyst" enabled="false" />
</ChildPackages>
</Package>
<Package id="ArcMapPythonScripting" name="Python Scripting" enabled="true" />
<Package id="ArcMapAdditionalDataFormats" name="Additional Data Formats" enabled="false">
<ChildPackages>
<Package id="ArcMapRaster" name="Raster" enabled="false">
<ChildPackages>
<Package id="ArcMapECWRasters" name="ECW Rasters" enabled="false" />
<Package id="ArcMapMosaicRasters" name="Mosaic Rasters" enabled="false" />
</ChildPackages>
</Package>
<Package id="ArcMapVector" name="Vector" enabled="false" />
<Package id="ArcMapSDE" name="SDE" enabled="false">
<ChildPackages>
<Package id="ArcMapAlitbase" name="Alitbase" enabled="false" />
<Package id="ArcMapDameng" name="Dameng" enabled="false" />
<Package id="ArcMapDB2" name="DB2" enabled="false" />
<!--Adds support for direct connect to geodatabases stored in Informix.-->
<!--Informix Drivers must be present on end users machine.-->
<Package id="ArcMapInformix" name="Informix" enabled="false" />
<Package id="ArcMapNetezza" name="Netezza" enabled="false" />
<Package id="ArcMapOracle" name="Oracle" enabled="false" />
<Package id="ArcMapPostgreSQL" name="PostgreSQL" enabled="false" />
<Package id="ArcMapSAPHANA" name="SAP HANA" enabled="false" />
<Package id="ArcMapSQLServer" name="SQL Server" enabled="false" />
<Package id="ArcMapSQLite" name="SQLite" enabled="false">
<ChildPackages>
<Package id="ArcMapSpatiaLite" name="SpatiaLite" enabled="false" />
</ChildPackages>
</Package>
<Package id="ArcMapTeradata" name="Teradata" enabled="false" />
</ChildPackages>
</Package>
</ChildPackages>
</Package>
<Package id="ArcMapAdditionalProjectionEngineTransformations" name="Additional Projection Engine Transformations" enabled="false" />
<Package id="ArcMapDebug" name="Debug" enabled="false">
<ChildPackages>
<Package id="ArcMapLogging" name="Logging" enabled="false" />
</ChildPackages>
</Package>
</ChildPackages>
</Package>
</Packages>
VijitWadhwa
New Contributor III
Mike I am simply trying to run one of the given samples
Local Server Services—ArcGIS Runtime SDK for .NET Samples | ArcGIS for Developers without making any changes in deployment file,
The Map Service and Feature Service start successfully , the problem comes only in geopackage (for starting geoprocessing service). This geoprocessing service is starts successfully when I run this sample in java, but in .NET , I am facing this issue from a long time and I am unable to resolve. I also tried making changes in deployment file , by changing the geoprocessing tags to true . But , the problem still persists. This is how the error appears
Please Help me resolving this , I am stuck in my development process because of this issue.
Thanks
MichaelBranscomb
If you're running the Contour tool, you will need to enable 3D Analyst or Spatial Analyst in your deployment configuration:
e.g.
<Package id="ArcMap3DAnalyst" name="3D Analyst" enabled="true" />
or
<Package id="ArcMapSpatialAnalyst" name="Spatial Analyst" enabled="true" />
Also, depending on what data types are used in the geoprocessing package you may need to enable some additional dataformats
e.g. I have enabled raster data support and vectoe data support below.
<Package id="ArcMapAdditionalDataFormats" name="Additional Data Formats" enabled="true">
<ChildPackages>
<Package id="ArcMapRaster" name="Raster" enabled="true">
<ChildPackages>
</ChildPackages>
</Package>
<Package id="ArcMapVector" name="Vector" enabled="true" />
Cheers
Mike
