How to reproject feature layer from esri server?
780
04-20-2017 11:04 AM
JosephKane
New Contributor II
Trouble loading feature layer in code behind.  This is in runtime 10.2.7.
In XAML I define my base map as..
<esri:Map>
                <esri:ArcGISTiledMapServiceLayer
                    ServiceUri="http://services.arcgisonline.com/ArcGIS/rest/services/World_Street_Map/MapServer" />
This map layer reports Spatial Reference: 102100 (3857)
Then in the code behind, i try to load the feature layer..
 string endpoint = "http://sampleserver3.arcgisonline.com/ArcGIS/rest/services/Fire/Sheep/FeatureServer/0";
            Uri featUri = new Uri(endpoint);
            var gdbServiceFeatureTable = await ServiceFeatureTable.OpenAsync(featUri);
            gdbServiceFeatureTable.OutFields = Esri.ArcGISRuntime.Tasks.Query.OutFields.All;
           FeatureLayer fl = new FeatureLayer(gdbServiceFeatureTable) { ID = endpoint };
            MyMapView.Map.Layers.Add(fl);
This map layer reports Spatial Reference: Spatial Reference: 4326
Nothing is visible in the map.
However, if I add this layer via XAML, it is visible.
Any help would be appreciated.
thanks,
joe
MichaelBranscomb
Esri Frequent Contributor
In 10.2.7 you should use one of the OpenAsync methods that takes a Spatial Reference parameter to initialize the ServiceFeatureTable in the SpatialReference of your Map.
ServiceFeatureTable.OpenAsync Method (Uri, String, SpatialReference)
Cheers
Mike
MichaelBranscomb
Cheers
Mike
JosephKane
New Contributor II
That's it!
Thanks, Mike.
