How to export the shape file in arcgis runtime sdk with help of localserver ?
711
08-27-2020 09:04 AM
HarshGupta
Michael Branscomb
Hi sir,
I deployed local server in my .net application it run successfully.
1) And also my gpk package is not perfectly genrated please help me ?
and
2) when i pass sample packege there  like featuretoshape (gpk) but unable to pass accurate parameter(geoprocessing parameter ) how to pass (geoprocessing parameter )  ?
HarshGupta
Michael Branscomb
hi sir
I created local server and hosted serive on it and shape file is also genrated
"C:/EsriSamples/AppData/Documents/ArcGIS/Packages/fctoshp_railway_E6EE0999-9E4D-4CFD-A6B0-FE6D85383425/p20/test" in this location
how to get this location by code ?
MichaelBranscomb
Esri Frequent Contributor
My recommendation is to expose the output location/folder as a string input parameter. You can then specify the desired output location in your code and the Local Geoprocessing Service will write the Shapefile directly to that location.
Documentation resources:
- For ModelBuilder Inline variable substitution—ArcGIS Pro | Documentation
- For Python Scripts Setting script tool parameters—ArcGIS Pro | Documentation
Mike
