How to create render from symbol Stylex
1512
02-23-2018 04:07 AM
Siva_SankaraReddy_T
New Contributor II
Hi all,
Created Stylx file in ArcGIS Pro. using SymbolStyle API, open the Symbol. But, how to create renderer to add graphicoverlay. please help me.
Tags (1)
OliverBoesche
New Contributor II
this shows the overall topic to your problem in C#. Think that could help.
Display military symbols with a dictionary renderer—ArcGIS Runtime SDK for .NET (WPF) | ArcGIS for D...
Regards,
Oliver
Siva_SankaraReddy_T
New Contributor II
Thanks for your reply. i tried following code.
 DictionarySymbolStyle symbolDictionary = await SymbolStyle.OpenAsync(@"D:\ArcGISRuntimeforJava\Test.stylx") as DictionarySymbolStyle;
Not access my stylx file. But it accessing sample mil2525d stylx file. Pls help me.
OliverBoesche
New Contributor II
Please try to Debug the smybolDictionary after the await. There is an attribute Loaded and Error that normally tells you what is wrong.
NagmaYasmin
Occasional Contributor III
You could use the below code to display .stylx file created from Pro. Attached is the sample application.
string file_to_stylx = parent.FullName + "\\Data\\style.stylx";
symbolStyle = await SymbolStyle.OpenAsync(file_to_stylx);
IList<String> stringList = new List<string>();
stringList.Add("shoppingcenter01");  // key file, you can get this key by opening .stylx file in SQLite database
SimpleRenderer simpleRenderer = new SimpleRenderer(await symbolStyle.GetSymbolAsync(stringList));
newFeatureLayer.Renderer = simpleRenderer;
Hope that helps.
SymbolStyleFromStylx
Siva_SankaraReddy_T
New Contributor II
Thanks for your help.
