How create .cal file with KmlDocument ?
538
09-15-2020 03:08 AM
CavronJeremy
New Contributor III
How can I convert a KmlDocument created with SketchEditor to a .cal file?
I try to close on the document but I don't have all the informations.
foreach (Object objChildNodes in mKmlDocument.ChildNodes)
   if (objChildNodes is KmlPlacemark)
      KmlPlacemark pl = (KmlPlacemark)objChildNodes;
      Console.WriteLine("type"); // I have type : Polygon, Polyline (only)
      Console.WriteLine(pl.GraphicType.ToString());
   foreach (Object obj in pl.Geometries)
      if(obj is KmlGeometry)
          KmlGeometry kGeo = (KmlGeometry)obj;
          Console.WriteLine("-- Geometrie");
          Console.WriteLine(kGeo.Geometry.SpatialReference.ToJson());
          Console.WriteLine(((KmlGeometry)obj).Geometry.ToJson());
          Console.WriteLine("Type");
          Console.WriteLine(kGeo.Type.ToString());
I don't have Style in KmlDocument, the same in KmlPlaceMark. Yet I do have line thickness and color on the SketchEditor.
Another thing.
I drew a rectangle. If I display the geometry in the console. It shows me the polygon or polyline type, but never rectangle, circle, etc...
thanks
CavronJeremy
New Contributor III
May be don't use Kml format and use directly GraphicsOverlay for extract informations.
CavronJeremy
New Contributor III
I find. I wasn't making any sense. To extract directly. You have to go to Graphics of SketchOverlay
