Help with call to Profile Task...
904
02-27-2019 02:48 PM
TimB
New Contributor III
Any good pointers or examples to help with the call and return data of this task from .Net code?
Task: Profile
https://elevation.arcgis.com/arcgis/rest/directories/arcgisoutput/Tools/ElevationSync_GPServer/Tools...
TimB
New Contributor III
OK,
So i used the geoprocessing/viewshed example to come up with the code below.  It makes the call and receives a reply.  However, the geometry that gets returned is only a polyline, and not a polylineZ (containing z values of the ground).  Does anyone have an idea why it does not appear to be working?  I thought it was something in the fieldlist but i tried multiple things there (including none), but nothing seemed to change the returned result.
            var myProfileTask = await GeoprocessingTask.CreateAsync(new Uri(_viewshedUrl));
            List<Field> fieldList = new List<Field>();
            fieldList.Add(new Field(FieldType.OID, "ObjectID", "ObjectID", 10));
            fieldList.Add(new Field(FieldType.Float64, "Shape_Length", "Shape_Length", 10));
            var myInputFeatures = new FeatureCollectionTable(new List<Field>(), GeometryType.Polyline, SpatialReferences.WebMercator);
            Feature myInputFeature = myInputFeatures.CreateFeature();
            _selectedGraphics[0].Attributes.Add("ObjectID", 1);
            _selectedGraphics[0].Attributes.Add("Shape_Length", GeometryEngine.LengthGeodetic(_selectedGraphics[0].Geometry,LinearUnits.Meters,GeodeticCurveType.Geodesic));
            myInputFeature.Geometry = _selectedGraphics[0].Geometry;
            await myInputFeatures.AddFeatureAsync(myInputFeature);
            GeoprocessingParameters myProfileParameters =
                new GeoprocessingParameters(GeoprocessingExecutionType.SynchronousExecute);
            myProfileParameters.OutputSpatialReference = SpatialReferences.WebMercator; ;
            myProfileParameters.Inputs.Add("InputLineFeatures", new GeoprocessingFeatures(myInputFeatures));
            var myViewshedJob = myProfileTask.CreateJob(myProfileParameters);
            try
                GeoprocessingResult myAnalysisResult = await myViewshedJob.GetResultAsync();
                GeoprocessingFeatures myProfileResultFeatures = myAnalysisResult.Outputs["OutputProfile"] as GeoprocessingFeatures;
                // Add all the results as a graphics to the map
                IFeatureSet myViewshedAreas = myProfileResultFeatures.Features;
                foreach (var myFeature in myViewshedAreas)
                    _resultOverlay.Graphics.Add(new Graphic(myFeature.Geometry));
            catch (Exception ex)
                // Display an error message if there is a problem
                //if (myViewshedJob.Status == JobStatus.Failed && myViewshedJob.Error != null)
                //    _userViewModel.UserMessage="Executing geoprocessing failed. " + myViewshedJob.Error.Message, "Geoprocessing error";
                //else
                //    MessageBox.Show("An error occurred. " + ex.ToString(), "Sample error");
            finally
                // Indicate that the geoprocessing is not running
                //SetBusy(false);
MichaelBranscomb
Esri Frequent Contributor
Here's the Python script I use with Local Server in a similar scenario:
import arcpy, math
inputLine = arcpy.GetParameterAsText(0)
inputRaster = arcpy.GetParameterAsText(1)
outputShapeZ = "in_memory\\outShapeZ"
outputShapeM = "in_memory\\outShapeM"
arcpy.ddd.InterpolateShape(inputRaster, inputLine, outputShapeZ)
arcpy.CreateRoutes_lr(outputShapeZ, "ident", outputShapeM, "LENGTH")
arcpy.SetParameterAsText(2, outputShapeM)
Create_Routes is optional, but that adds measure values along the line.
Using it with Local Server is the same workflow you probably already have:
- Import the Python Script to a Toolbox (ensure you check the relative path option)
- Define any parameters needed (in my case above that's two input strings and one derived/output parameter)
- Run the new script tool in ArcGIS Pro / ArcMap
- Run the Package Result tool and check the option to enable for ArcGIS Runtime
Cheers
Mike
TimBranscomb
Thanks for the reply.  Unfortunately, in my use case scenario, i won't have localserver available.  Any insight into why the call my be just returning a 2d line, and not the expected polylineZ?  Are my inputs wrong?  What i am most unsure about are my 'fieldlist' inputs as well as my attributing for the input line.  The GP Task expects the following fields: OID, Shape_Length
BTW, hope you are doing well! -Tim B (you can guess the last name)
TimBranscomb
Finally!  Figured it out.  I will post the entire code in a bit, but in the mean time, this is what i was missing:
Snippet
myProfileParameters.ReturnZ = true;myProfileParameters.ReturnM = true;
