Get symbol for a FeatureTemplate
697
05-03-2018 04:10 PM
MarkCollins
Hello,
I was wondering if there is a way to get the symbol for a FeatureTemplate?  I'm trying to build a grid of feature templates for the user to choose from when editing a map layer.
In the old WPF API it used to work this way...
featuretemplate.GetSymbol(layer.Renderer)
I haven't been able to find anything that appears to be equivalent in the docs or object model.
Mark
RichZwaap
Occasional Contributor III
You can use the Renderer.GetSymbol method for this. That requires a GeoElement, which you can create from the feature template's PrototypeAttributes.  So the code would be something like:
// We need a layer to access the renderer
var featureLayer = new FeatureLayer(
  new Uri("https://sampleserver6.arcgisonline.com/arcgis/rest/services/CommercialDamageAssessment/FeatureServer..."));
// The layer needs to be loaded to make its metadata accessible
await featureLayer.LoadAsync();
// With this particular service, the feature templates are enclosed in feature types,
// so get the feature type first.  Some services have the feature templates available
// directly off of the layer info.
var featureType =
  ((ServiceFeatureTable)featureLayer.FeatureTable).LayerInfo.FeatureTypes.First();
// Get the feature template
var featureTemplate = featureType.Templates.First();
// Create a graphic with the feature template's attributes
var prototypeGraphic = new Graphic(featureTemplate.PrototypeAttributes);
// Use the graphic to get the symbol from the renderer
var featureTemplateSymbol = featureLayer.Renderer.GetSymbol(prototypeGraphic);‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍
Hope this helps.
RichZwaap
var featureType =
Hope this helps.
MarkCollins
Rich,
This was exactly what I was looking for and it works great. Thanks for the help!
-Mark
