Geoserver and WMS Tiled
2227
6
08-30-2018 01:49 AM
GonzaloMuöoz
I have a program that connects with geoserver through a getcapabilities request with arcgis sdk:
  WmsLayer myWmtsService = new WmsLayer(new Uri("http://localhost:8070/geoserver/World/wms?SERVICE=WMS&tiled=true&REQUEST=getcapabilities&VERSION=1.1... "));
the problem is that when I add it to de mapview, it behaves itself as singletile and I would like arcgis to ask layers tiling. An example: if height and width of the mapview is 1000x1000, now arcgis makes a getmap request with height and width 1000x1000, but I'd like it to make several getmap requests with hegith and width 250x250.
How can I make the arcgis code to configure it to work this way?
Thanks
Regards
MichaelBranscomb
Esri Frequent Contributor
Are you using ArcGIS Runtime SDK for .NET v100.3?
Cheers
Mike
GonzaloMuöoz
Yes, that's it.
GonzaloMuöoz
Hi again Michael,
Do you have any clue about this?
Thanks
Regards
MichaelBranscomb
Can you use the WmtsLayer Class instead?
Cheers
Mike
GonzaloMuöoz
we have been using previously WMTS services with geowebcache in our app with a image pyramid stored in geoserver, but it loads the image on our app really slow, that's why we tried to change to WMS services with geowebcache direct integration...
Is it normal that the image load with WMTS and geowebcache goes really slow?
Thanks
Regards
CharlesRoberts1
New Contributor III
I have the same request. In a nutshell, GeoServer wants tiled=true in each subsequent (WmsLayer generated) request as well as the initial GetCapabilities request. Also, the image size needs to be set to the desired tile size, for example, 256,256.
