Follow Mode
3275
13
12-21-2020 02:05 AM
GonzaloMuöoz
I'm using ArcGIS Runtime .net 100.9 version. I'd like to know if there's a way of center constantly the map on the movement of an element. What I'm using now is to when moving the element, make a SetViewpointCenterAsync, but it's not a valid approach since the map's center is changed everytime. Map should stay centered all the time on the element without any visual effect.
Regards
Gonzalo
GonzaloMuñoz
Hi @sandiegomonedero,
it took me some time but I've been able to change the code according to the clear and addrange idea, but it has the same wrong behavior.
Regards
Gonzalo
JoeHershman
MVP Regular Contributor
Did you ever play around with WanderExtent to get it to change how quickly it recenters?  Setting to 0 should have it continuously recentering
-Joe
GonzaloMuöoz
Hi @JoeHershman,
yes as stated in my comment of January I made multiple tests but none of them was succesful.... Have you tried this functionality with a correct behavior?
MichaelBranscomb
Esri Frequent Contributor
@GonzaloMuöoz We'll work with you through your Support case to help you find the right solution.
