Feature Service Edit capabilities
359
07-28-2017 07:45 AM
ManelKEDDAR
While i was checking the doc about editing features Edit features—ArcGIS Runtime SDK for .NET (WPF) | ArcGIS for Developers   it's mentioned that i should check these capabilities to determine what editing capability is available , my question is where i should check this ? i use arcMap as arcGis desktop tool
i'm doing this cause i don't have the ability to edit my featureClasses using the mobile Geodatabase and the featureServices using (.mpk) .
It's mentioned also that ownership-based access control must be checked ?where i can check this on ArcMap i dont use arcGis for server !
any one can help or clarify
thanks in advance
Cheers
