Feature layers don't display on the map (WPF Application)
6462
21
10-16-2014 03:05 AM
deleted-user-i8mW0s-ySag1
With the release of ArcGIS Runtime SDK 10.2.4, I've read the developer's guide and tried to do the various tutorials.
But I have a problem with the part "Add a feature layer to provide operational data" (https://developers.arcgis.com/net/desktop/guide/access-feature-data-in-the-cloud.htm).
When I add a feature layer on the base map, it doesn't display at all, no matter how I try (by XAML or by code). I even used the layer.InitializationException to check if it was correctly loaded. All I can see is the basemap without the swimming pool permits layer.
For your informations, I'm working with Visual Studio 2013 Express Edition.
Can you please help me to find what I'm doing wrong?
Thanks in advance for your answers.
Here's the code I use for my basic project (WPF Application in Visual Basic):
<Window x:Class="MainWindow"
    xmlns="http://schemas.microsoft.com/winfx/2006/xaml/presentation"
    xmlns:x="http://schemas.microsoft.com/winfx/2006/xaml"
    xmlns:esri="http://schemas.esri.com/arcgis/runtime/2013"
    Title="MainWindow" Height="536.596" Width="888.705">
    <Grid>
        <esri:MapView x:Name="MyMapView">
            <esri:Map x:Name="MyMap">
                <esri:ArcGISTiledMapServiceLayer ID="BaseMap"
                    ServiceUri="http://services.arcgisonline.com/ArcGIS/rest/services/World_Imagery/MapServer"/>
                <esri:FeatureLayer ID="PoolPermits">
                    <esri:FeatureLayer.FeatureTable>
                        <esri:ServiceFeatureTable
                           ServiceUri="http://sampleserver6.arcgisonline.com/arcgis/rest/services/PoolPermits/FeatureServer/0"/>
                    </esri:FeatureLayer.FeatureTable>
                </esri:FeatureLayer>
                <esri:Map.InitialViewpoint>
                    <esri:ViewpointExtent XMin="-13075816.40"
                   YMin="4014771.46"
                   XMax="-13073005.67"
                   YMax="4016869.78"/>
                </esri:Map.InitialViewpoint>
            </esri:Map>
        </esri:MapView>
    </Grid>
</Window>
Grégoire
DominiqueBroux
Esri Frequent Contributor
Looks like the PoolPermit feature server<http://sampleserver6.arcgisonline.com/arcgis/rest/services/PoolPermits/FeatureServer> is no longer working well.
Even the arcgis.com viewer<http://www.arcgis.com/home/webmap/viewer.html?url=http%3A%2F%2Fsampleserver6.arcgisonline.com%2Farcgis%2Frest%2Fservices%2FPoolPermits%2FFeatureServer&source=sd> is not able to display the features.
Error returned by the server:
{"error":{"code":500,"message":"Error performing query operation","details":[]}}
/Dominique
Indeed, you're right, thanks. But the PoolPermit feature service was working yesterday! I was able to open it directly in arcgis.com.
Homever, my problem remains. I've tried to create an application with internal datas using an
ArcGISDynamicMapServiceLayer and a FeatureLayer (like the example). The first was visible but not the second. And I could see all my features with the ArcGIS.com Map viewer.
DominiqueBroux
PoolPermit service is up again. I tested your code and it seems working.
Could you try again?
If you are experiencing issue with another services, please share your code so we can reproduce the issue.
Thanks.
Thank you for your help.
Indeed, The PoolPermit is up again. But my code still doesn't work on my side. For your information, I've created a WPF application (Visual Basic) in Visual Studio Express 2013 (my test platform is on Windows 7). I've pasted my code in the MainWindow.xaml and this is the result I get:
Could it be a problem with the Visual "Express" edition? Or with some parameters of the solution? (I've left everything by default) I've also tried a WPF application in C# with the same result.
AnttiKajanus1
Occasional Contributor III
Have you checked if there is any errors when layer is loaded? You can access to that from MapView.LayerLoaded event.
Also could you check what data is fetched from the server using Fiddler etc.
Thank you for your tips.
I've tried the mapView.LayerLoaded event and the PoolPermits layer was loaded successfully.
And here's a screenshot of the traffic data through Fiddler:
Everything seems allright.
I've opened the tiles under the FeatureServer (in Fiddler) and there isn't any pool drawed on the map (only the base map).
Here's the complete url sent:
/arcgis/rest/services/PoolPermits/FeatureServer/0/query?outFields=objectid%2Chas_pool&outSR=3857&returnGeometry=true&geometry=%7B%22rings%22%3A%5B%5B%5B-13076254.949469188%2C4014763.0498995488%5D%2C%5B-13076254.949469188%2C4016878.190100451%5D%2C%5B-13072567.120530812%2C4016878.190100451%5D%2C%5B-13072567.120530812%2C4014763.0498995488%5D%2C%5B-13076254.949469188%2C4014763.0498995488%5D%5D%5D%2C%22spatialReference%22%3A%7B%22wkid%22%3A102100%2C%22latestWkid%22%3A3857%7D%7D&geometryType=esriGeometryPolygon&inSR=102100&spatialRel=esriSpatialRelIntersects&f=json
AnttiKajanus1
What was the response from the server?
I tried the code that you posted in the original post and it seems to work for me. Going to test that in express edition but need to install it first.
Just for kicks, can you try to set CultureInfo to en-US or GB and see if that helps. I assume that you are using some other. Or can you let me know what you are using?
Here's the response from the Server:
{"objectIdFieldName":"objectid","globalIdFieldName":"","geometryType":"esriGeometryPolygon","spatialReference":{"wkid":102100,"latestWkid":3857},"fields":[{"name":"objectid","alias":"OBJECTID","type":"esriFieldTypeOID"},{"name":"has_pool","alias":"Has_Pool","type":"esriFieldTypeInteger"}],"features":[{"geometry":{"rings":[[[-13073563.808187518,4016000.5893990993],[-13073539.07662103,4015994.5016283691],[-13073500.561194843,4015994.182299681],[-13073501.322782392,4015900.7540653944],[-13073501.607079294,4015893.4926456138],[-13073502.34006433,4015886.2629382163],[-13073503.519120546,4015879.0929854736],[-13073505.139425823,4015872.010486193],[-13073507.195057658,4015865.0431517512],[-13073509.677879972,4015858.2176130638],[-13073512.578285273,4015851.5601492599],[-13073515.021006852,4015846.6929872781],[-13073518.624360956,4015840.3916177973], ...
I've tried to change the CultureInfo to en-US without success. My CultureInfo is "fr-CH".
Thanks for your help.
