Feature Layer Drawn in incomplete state
725
08-26-2019 12:59 AM
YashvitNaik
New Contributor III
I am using the latest version of xamarin sdk for esri i.e. 100.5.0, I have a Feature Layer that has MinScale and MaxScale set to 0. Visibility set to “true” and is of type esriGeometryPolygon.
On completion of first load, this layer is drawn successfully on the map but it is incomplete. On zooming to a certain level however over the incomplete area, the layer start showing up, although there is no zoom level set.
This behaviour only persists when executed using the xamarin sdk on both android and iOS Applications, The same Layer However, is drawn completely (on first load ) on our Hosted site that use ArcGIS Javascript api.  Layer data and Screen shots attached below from both sources.
Thanks
JoeHershman
MVP Regular Contributor
I assume it is connected service table.  There is a limit to the number of features that will be returned which can be changed on the server.  Not sure why javascript would behave differently
-Joe
