Feature Layer added nothing popup
1141
8
10-17-2021 11:29 PM
batkaj
New Contributor II
Feauture layer has been added it's showing up on the map.
nothing on popup.
MichaelBranscomb
Esri Frequent Contributor
Can you share your code (e.g. XAML) where you've configured the UI to display the contents of the Popup?
Thanks
batkaj
New Contributor II
The popup is working mumps which is downloaded.
not working on feature layer. 
dotMorten_esri
Esri Notable Contributor
Is `result?.Popups?.FirstOrDefault() is Popup` true? Does that feature layer have popups configured?
batkaj
New Contributor II
how can I share my code
batkaj
New Contributor II
result?.Popups?.FirstOrDefault() is Popup giving null.
dotMorten_esri
Did you define a popup definition on your feature layer? Otherwise that collection would be null.
batkaj
New Contributor II
didn't
I'm looking at this code https://developers.arcgis.com/net/wpf/sample-code/show-popup/
do you have a example popup definition.
batkaj
New Contributor II
Popupdefinition still the same.
