ESRI Xamarin apps in the Appstore
732
09-09-2017 01:16 PM
BledarBirbo
New Contributor III
Hi.
Is there any known application that is using ESRI .NET runtime for iOS (Xamarin) and is currently live on the AppStore ?
Has anyone found any issues getting the Applications which are build with ESRI .NET runtime 100 (Xamarin)  approved by Apple ?
Thanks.
RichZwaap
Occasional Contributor III
We did not actually activate the listing, as it's not an app that we want available through the App Store.  We took the app through the approval process -  right up to the point of being able to activate the listing - as a test to ensure that there were no issues in doing so.
RichZwaap
There was an issue with version 100.0 that was preventing apps from being submitted to the App Store, but a hotfix was released to address that, and the issue was resolved at 100.1.  Internally, we have taken our samples application all the way through the App Store approval process and have received approval to list it in the store.  The only issue encountered along the way that was specific to the Runtime is that it causes the application size to be large enough that wi-fi is required to install it.  This does not prevent App Store approval, but it will raise a warning during the approval process.
BledarBirbo
New Contributor III
Hi.
Thanks for the quick reply.
Is it possible to share the AppStore Links for the sample apps that you passed on the AppStore ?
RichZwaap
