ESRI Minor Bug - Possible Incorrect Error Code Entry in Runtime Guide
535
05-18-2018 12:07 AM
EdL
Version: ArcGIS Runtime.WPF 100.2.1
Network analyst error code 5024 - Network Analyst No path found between stops exception (ArcGIS Runtime WPF error codes).
Actual error code returned (C# Net) - Network analyst error code 5022
I am experiencing this minor issue where the actual returned code in the program is 5022 which is different from the documented guide.
MichaelBranscomb
Esri Frequent Contributor
Thanks for the feedback - we'll submit an issue to investigate and correct the doc (assuming it is in fact just a doc issue).
Cheers
Mike
