Deadlock in 100.8
763
07-01-2020 02:10 PM
MattRickard
New Contributor II
I asked a question recently about deadlocks in 100.7.
Michael Branscomb‌ answered my question and I upgraded to 100.8
That upgrade made my experience much better, but as our testers have used it more, deadlocks are still occurring.
The callstacks are a little different than what I had seen in 100.7.
I have attached a txt file with the callstack details.
In the minidump I got from him, there are 45 threads waiting at mtx_do_lock.
The summary of threads is:
  • Esri_runtimecore::Geo_views::Map_view::set_viewpoint_
  • Esri_runtimecore::Map_renderer::Canvas_drawable::highlight_color
    • from addlayer
  • Esri_runtimecore::Map_renderer::Map::copy_display_properties(void)
    • from CoreGeoView.Pulse
  • Esri_runtimecore::Geo_views::Geo_view::update_attribution_(void)
    • There are a lot of threads with this same callstack.
The second attachment, "100.8.hang2.txt" is an example when I was debugging.
The summary is:
  • Esri_runtimecore::Geo_views::Map_view::set_view_insets_
    • on the main/dispatcher thread
    • 2 threads with this callstack this time.
    • from addlayer
Any ideas?
Matt
MattRickard
New Contributor II
Any feedback on this Michael Branscomb‌?  This is becoming a more prevalent issue with our user base.
FYI, we are doing some off-screen rendering of a map for printing, as recommended by Rex Hansen.
This may be contributing to the problem, but certainly not the sole cause.
MichaelBranscomb
Esri Frequent Contributor
Can you provide more information regarding:
- The system/environment (ideally a dxdiag report from 2-3 machines on which you are able to reproduce the issue you are seeing)
- What your application is doing at the time of the hang (if you are able to ascertain that) (e.g. user zoomed in)
- The composition of the map in terms of basemap layers (e.g. vector tiled layer), operational layers (e.g. feature layers from service feature table), and graphics overlays.
- Any specific UI interactions you have running e.g. identify on mouse move.
If you're not able to share here - please email mbranscomb@esri.com.
Thanks
Mike
