Creating Polygon at runtime using mouse clicks
1368
04-23-2021 03:57 PM
ManishShrivastav
New Contributor III
I am trying to draw a polygon on the fly in a map view. Is there any tool available in arcgis runtime sdk for .net (using 100.9.0).
I am using https://developers.arcgis.com/net/wpf/sample-code/cut-geometry/ as a sample, but instead of providing MapPoints() as coordinates in code file, I want to register the mouse click at runtime and use those clicks as input points to draw a polygon on the MapView.
Your help is greatly appreciated.
Manish
JoeHershman
MVP Regular Contributor
To draw a shape based on user input you use the SketchEditor.StartAsyn method.  There is a simple example shown on the help page
https://developers.arcgis.com/net/wpf/api-reference/html/M_Esri_ArcGISRuntime_UI_SketchEditor_StartA...
-Joe
ManishShrivastav
New Contributor III
Thanks for pointing out the resource but after creating the polygon according the resource I am not able to conduct any kind of geoprocessing on it. It is just like a graphic on my map. Please let me know if there is anything I am missing.
Thanks
JoeHershman
The SketchEditor simply creates a geometry.  If you want a feature you will need to create a feature set the geometry and then add that to the table
-Joe
