Crash in .net Runtime SDK on iOS device
888
05-22-2018 02:51 PM
CalebPourchot
I'm getting this crash dump reported from my microsoft App Center logs. My iOS app is built with Xamarin.Forms on .net using the 100.2.1 version of the runtime SDK. I have no repro case for it. It is occurring on iOS 11.3.1. I'm hoping the crash dump will tell you guys something useful. I don't expect an answer.
Thanks!
Caleb
Esri_runtimecore::HAL::multi_draw_arrays_ogl(Esri_runtimecore::Graphics_abstraction::Primitive_type, int*, int*, int)
SIGSEGV
BACKGROUND THREAD 29 - CRASHED
  • 0
    AGXMetalA11
    0x1ab8f7000 + 562748
  • 1
    AppleMetalGLRenderer
    GLDContextRec::setRenderProgramUniforms()
  • 2
    GLDContextRec::setRenderState(unsigned int)
  • 3
    gldRenderVertexArray(GLDContextRec*, unsigned int, unsigned int, int, int, unsigned int, void const*, int, void const*)
  • 4
    GLEngine
    glDrawArrays_ACC_ES2Exec
  • 5
    ArcGIS-arm
  • 6
    ArcGIS-arm
    Esri_runtimecore::HAL::Tex_quad_shader_program::draw_quad(std::__1::shared_ptr<Esri_runtimecore::HAL::Device> const&, std::__1::shared_ptr<Esri_runtimecore::HAL::Texture> const&, float, Esri_runtimecore::Graphics_abstraction::Texture_sampling_mode, unsigned int, double const (&) [8], Esri_runtimecore::HAL::Tex_quad_shader_program::Vertex const (&) [4])
  • 7
    ArcGIS-arm
    Esri_runtimecore::Map_renderer::Image_drawable::Image_container::draw(std::__1::shared_ptr<Esri_runtimecore::HAL::Device> const&, std::__1::shared_ptr<Esri_runtimecore::HAL::Tex_quad_shader_program> const&, std::__1::shared_ptr<Esri_runtimecore::Map_renderer::Display_properties> const&, bool)
  • 8
    ArcGIS-arm
    Esri_runtimecore::Map_renderer::Image_drawable::draw_(std::__1::shared_ptr<Esri_runtimecore::HAL::Device> const&, std::__1::shared_ptr<Esri_runtimecore::Map_renderer::Display_properties>, float)
  • 9
    ArcGIS-arm
    Esri_runtimecore::Map_renderer::Canvas_drawable::draw(std::__1::shared_ptr<Esri_runtimecore::HAL::Device> const&, std::__1::shared_ptr<Esri_runtimecore::Map_renderer::Drawable::Render_properties> const&, std::__1::shared_ptr<Esri_runtimecore::Map_renderer::Display_properties> const&)
  • 10
    ArcGIS-arm
    Esri_runtimecore::Map_renderer::Map::draw(std::__1::shared_ptr<Esri_runtimecore::HAL::Device> const&)
  • 11
    ArcGIS-arm
    Esri_runtimecore::Mapping::Map_view::draw(Esri_runtimecore::Mapping::Device&)
  • 12
    ArcGIS-arm
    RT_GeoView_draw
  • 13
    ArcGIS-arm
    CoreRT_GeoView_draw
  • 14
    Landscape.Mobile.iOS
    wrapper_managed_to_native_RuntimeCoreNet_GeneratedWrappers_CoreGeoView_CoreRT_GeoView_draw_intptr_intptr_intptr_ <unknown>:1
  • 15
    RuntimeCoreNet_GeneratedWrappers_CoreGeoView_Draw_RuntimeCoreNet_GeneratedWrappers_CoreDevice <unknown>:1
  • 16
    Esri_ArcGISRuntime_UI_Controls_GeoView_RequestRender_bool <unknown>:1
  • 17
    Esri_ArcGISRuntime_UI_Controls_GeoView_RuntimeCoreNet_GeneratedWrappers_ICoreCallback_GeoView_DrawRequested_DrawRequested <unknown>:1
  • 18
    RuntimeCoreNet_GeneratedWrappers_CoreGeoView_onPrivateCoreGeoView_DrawRequested_intptr <unknown>:1
  • 19
    wrapper_native_to_managed_RuntimeCoreNet_GeneratedWrappers_CoreGeoView_onPrivateCoreGeoView_DrawRequested_intptr <unknown>:1
  • 20
    ArcGIS-arm
    std::__1::function<void (void*)>::operator()(void*) const
  • 21
    ArcGIS-arm
    Esri_runtimecore::Common::Signal<Esri_runtimecore::Mapping::Geo_view const>::operator()(Esri_runtimecore::Mapping::Geo_view const&) const
  • 22
    ArcGIS-arm
    Esri_runtimecore::Mapping::Geo_view_draw_requested::draw_request_callback()
  • 23
    ArcGIS-arm
    Esri_runtimecore::Map_renderer::Map::on_pulse_()
  • 24
    ArcGIS-arm
    Esri_runtimecore::Map_renderer::Pulse_thread::execute_()
  • 25
    ArcGIS-arm
    Esri_runtimecore::Common::Thread::thread_proc(Esri_runtimecore::Common::Thread*)
  • 26
    ArcGIS-arm
    void* std::__1::__thread_proxy<std::__1::tuple<std::__1::unique_ptr<std::__1::__thread_struct, std::__1::default_delete<std::__1::__thread_struct> >, void (*)(Esri_runtimecore::Common::Thread*), Esri_runtimecore::Common::Thread*> >(void*)
  • 27
    libsystem_pthread.dylib
    _pthread_body
  • 28
    _pthread_start
  • 29
    thread_start
