coordinate conversion
1435
02-27-2018 03:55 AM
MarcHillman
New Contributor III
I need a little help. I have been successfully reading a number of shapefiles, extracting the polygons, and exporting them as KML. All works well, but now I've hit a shapefile that isn't WGS84. How do I convert all the points to WGS84?
I know the shapefile uses EPSG:2193.
To keep the KML file to a sensible size, I also do a generalize.
Not sure whether I transform "compressed" or "geo" in the code below.
Any help much appreciated.
For Each fragment As Esri.ArcGISRuntime.Data.GeodatabaseFeature In fragments
                Dim compressed As Esri.ArcGISRuntime.Geometry.Geometry = Esri.ArcGISRuntime.Geometry.GeometryEngine.Generalize(fragment.Geometry, My.Settings.TrackSmoothness * DegPerM, True)
                Dim geo As Esri.ArcGISRuntime.Geometry.Polygon = compressed
Skill level - knows enough to be dangerous.
Tags (1)
dotMorten_esri
Esri Notable Contributor
Sorry for the C# (I've long forgotten my VB skills), but here's how you would project a geometry to WGS84:
Geometry geometryWgs84 = GeometryEngine.Project(inputGeometry, SpatialReferences.Wgs84);
DanPatterson_Retired
Project.. the shapefile to a Geographic Coordinate System (aka unprojected.  a GCS WGS84 will do), then export to kml  The same tool exists in ArcMap and PRO, depending on which platform you are using
MarcHillman
New Contributor III
Examples are sparse, but this is as far as I've gotten
                Dim WGS84 As New Esri.ArcGISRuntime.Geometry.SpatialReference("WGS84")  ' datum for Google Earth
                Dim converter As New ProjectionConverter()
                compressed = converter.Convert(compressed, TypeOf compressed, WGS84, System.Globalization.CultureInfo.InvariantCulture)
I can't for the life of me work out what the Type parameter (2nd) of convert should be.
dotMorten_esri
MarcHillman
New Contributor III
Brilliant! It's easy when you know how. Solves problem completely. Thanks for getting me past my roadblock.
