We would like to show complex labels in RunTime.
We use ArcMap to create a mpk and we use the advanced option in labels.
If the labels are in VBScript we get a message that it is not supported.
If the labels are in Python we create a mpk and load it to runtime with no errors but the labels are not visible (got a bug from ESRI on this).
I understand it should work if you use arcade in pro but we use ArcMap to create mpk's
Anybody doing it?
Thanks
Just tried to create complex labels in Pro using Arcade and pack it in mmpk.
Still labels are not visible when I load it into RunTime 100.1
v100.2 will be adding support for Arcade expressions.
I just tried to create labels in JScript and it looks like it is working!!
In the screenshot you can see the expression and labels in ArcMap and the RunTime application (version 100.0).
