I am trying to use a callout at a point on the map,
await myCalloutDefinition.SetIconFromSymbolAsync(Map.WaypointMultiSymbol);
to set a symbol
and when its completed
mapView.ShowCallOutAt(mapLocation, myCallout);
If you make the symbol bigger, its appears to have no effect on the callout. How can you do this and change the size of the text in myCallout.titleString?
If using WPF, I believe Callouts are UIElements. Which suggest that you can make a UserControl, and use the ShowCallOut() method that takes in a UIElement for the callout. I believe you should then be able to set the size of the UserControl and its elements.
Not sure if there is a better way for this.
