Black Borders on GeoTiffs imported to RasterLayer type
973
05-03-2021 11:33 AM
justinfernandes
New Contributor II
When i load this geotiff into my ArcgisRuntime UWP app i have black borders where there are no valid pixels.  When i load the same geotiff into arcgisPro, i get transparent borders.
Is there a way to show these "non-valid pixels" as transparent in my arcgis runtime UWP app?
geotiff under question is attached.
 no borders in arcgisProno borders in arcgisProblack borders in arcgisRuntime UWPblack borders in arcgisRuntime UWP
MichaelBranscomb
Esri Frequent Contributor
Try setting the background color with a Raster Function - example code below.
async Task AddRasterAndSetBackgroundColorValue()
    try
        // Create a raster dataset from a local file raster.
        Raster raster = new Raster(@"..\FileRaster.tif");
        // Await the Load to catch any errors.
        await raster.LoadAsync();
        // Create a raster function from the JSON string using the static/Shared method called: RasterFunction.FromJson(json as String)
        RasterFunction rasterFunction = RasterFunction.FromJson(jsonFunction);
        // Get the raster function arguments
        RasterFunctionArguments rasterFunctionArguments = rasterFunction.Arguments;
        // Get the list of raster names from the raster function arguments.
        IReadOnlyList<string> rasterNames = rasterFunctionArguments.GetRasterNames();
        // Set the local file raster as a raster name argument.
        rasterFunctionArguments.SetRaster(rasterNames[0], raster);
        // Create a new raster based on the raster function.
        Raster rasterWithFunction = new Raster(rasterFunction);
        // Create a new raster layer from the raster with function applied.
        RasterLayer rasterLayer = new RasterLayer(rasterWithFunction);
        // Add RasterLayer with function to Map OperationalLayers collection.
        Map.OperationalLayers.Add(rasterLayer);
    catch (Exception ex)
string jsonFunction =
    ""raster_function"":{""type"":""Mask_function""},
    ""raster_function_arguments"":
        ""nodata_values"":{""double_array"":[0],""type"":""Raster_function_variable""},
        ""nodata_interpretation"":{""nodata_interpretation"":""all"",""type"":""Raster_function_variable""},
        ""raster"":{""name"":""raster"",""is_raster"":true,""type"":""Raster_function_variable""},
        ""type"":""Raster_function_arguments""
    ""type"":""Raster_function_template""
MichaelBranscomb
    try
justinfernandes
New Contributor II
you are my hero.  thank you!
