ArcGIS Runtime 100.2.1 crashes on Android 8.0 (API 26)
2019
8
04-24-2018 06:12 AM
SandeepKuniel1
New Contributor III
We are working with Xamarin Forms + Runtime and this does not seem to work with emulators/devices having android 8. Attached is a simple implementation to replicate the issue.
RichZwaap
Occasional Contributor III
Just to be extra sure, can you try this?
  1. Uninstall the app from the target device
  2. Delete the output folder (bin folder in the project directory by default)
  3. Delete the intermediate folder (obj folder in the project directory by default)
  4. Rebuild and re-deploy
This is just to ensure that the Mono Shared Runtime and Fast Deployment are no longer being used.
RichZwaap
Have you tried disabling "Use Shared Runtime" and "Use Fast Deployment?"  Those are under Android Options --> Packaging Properties on the project's properties page.  Then uninstall the app from emulator or device and do a full rebuild/redeploy.
SandeepKuniel1
New Contributor III
Hi Rich,
So there were 2 issues, on the emulator as you suggested.
disabling "Use Shared Runtime" and "Use Fast Deployment?" worked fine with the test app.
But in our app, we had one more issue caused due to the version 4.2.2
ArcGIS Runtime 100.2.1 does not work with Xamarin Forms and Android 4.2.2
The fix for the above was to include this.
 JavaSystem.LoadLibrary("runtimecore");//which did not work with version 8.
So the final fix was to do this.
if (Build.VERSION.SdkInt <= BuildVersionCodes.JellyBean)
 JavaSystem.LoadLibrary("runtimecore"); // fix for the android version 4.2
Regards
Sandeep
RichZwaap
Thanks for letting us know that the LoadLibrary call fails for you on newer versions of Android.  I suspect that will fail on Android 7 and up due to restrictions that were introduce in the loading of 3rd party libraries at run-time.  Also, I would expect that disabling "Shared Runtime" and "Fast Deployment" on Android versions prior to 8.0 is not necessary.  At least, I've not seen a problem with that at earlier versions.
RAHULPANDIA
New Contributor II
Any update on it?We are facing the same issue.
We have downloaded the runtime (Xamarin) on  27/July/2018, and it is sucessfully running on android api level 24(nugget7.0) but not above it.
Xamarin Forms version:3.0X
The app is workingg in UWP
Arcgis Runitme(.net) is 100.3
dotMorten_esri
Esri Notable Contributor
Did any of the above suggestion workarounds work for you? Did you update your Xamarin tooling / Visual Studio to the latest version?
RAHULPANDIA
New Contributor II
Visual studio 2017(have all the latest update)
Disabled the  "Shared Runtime" and "Fast Deployment"
Added the Java runtime
Yes have been updating xamarin forms to version 3
RichZwaap
RAHULPANDIA
New Contributor II
Thanks! This solved the issue along with Disabled the  "Shared Runtime" and "Fast Deployment"
