ArcGIS .Net SDK 10.2.7 - Call to Geoprocess SubmitJobAsync no returning JobID
500
07-12-2019 11:30 AM
DiegoLlamas
Hello,
I created a WCF Web Service that uses ArcGIS .NET SDK 10.2.7. In the web service I am calling a secured geoprocessing task.
Before calling the geoprocessing task I’m logging in to the portal using IdentityManager so I have access to the secured geoprocessing task.
However the call to the geoprocessing task SubmitJobAsync is returning a status of New and jobID null. The result should return
a status of Submitted along with a JobID. The geoprocess is created with ArcGIS Server 10.7.
I wasn’t able to find any documentation regarding that case and how to deal with it.
Code snippet for login:
public async Task GenerateToken()
            try
                var opt = new GenerateTokenOptions();
                opt.TokenAuthenticationType = TokenAuthenticationType.ArcGISToken;
                //orig
                var cred = await IdentityManager.Current.GenerateCredentialAsync(config.PortalAuthentication.ServiceUri,
        config.PortalAuthentication.username,
        config.PortalAuthentication.password,
        opt);
                //test
                //var cred = await IdentityManager.Current.GenerateCredentialAsync(config.PortalAuthentication.ServiceUri,
                //        config.PortalAuthentication.username,
                //        config.PortalAuthentication.password);
                IdentityManager.Current.AddCredential(cred);
            catch (ArcGISWebException webExp)
                Debug.WriteLine("Unable to authenticate : " + webExp.Message);
            catch (Exception exception)
                Debug.WriteLine("Unable to authenticate : " + exception.Message);
Snippet for geoprocessing task call:
public async Task<string> CallingMaps(string template, string array, string geo, string ctrl)
            DBConnection connection = new DBConnection();
            string storePath = string.Empty;
            try
                //List<Objects.OrderItemCatastral> allCat
                //var serviceURL = "http://mapas.gmtgis.net/arcgis/rest/services/Geoprocesos/ProductosCartograficos/GPServer";
                //string taskName = "Mapas de Catastro";
                var gp = new Geoprocessor(new Uri(config.MapasCatastral));
                //Set up the parameters
                var parameter = new GPInputParameter();
                var layoutTemplate = new GPString("Layout_Template", template);
                var pageRange = new GPString("Page_Range", array);
                var georef = new GPString("Georef_info", geo);
                var control = new GPString("Control", ctrl);
                parameter.GPParameters.Add(layoutTemplate);
                parameter.GPParameters.Add(pageRange);
                parameter.GPParameters.Add(georef);
                parameter.GPParameters.Add(control);
                //Execute task with the parameters collection defined above
                var result = await gp.SubmitJobAsync(parameter);
                while (result.JobStatus != GPJobStatus.Cancelled && result.JobStatus != GPJobStatus.Deleted && result.JobStatus != GPJobStatus.Succeeded && result.JobStatus != GPJobStatus.TimedOut && result.JobStatus != GPJobStatus.Failed)
                    try
                        result = await gp.CheckJobStatusAsync(result.JobID);
                        Debug.WriteLine(result.JobStatus +" Catastral ");
                        await Task.Delay(5000);
                    catch (System.Threading.Tasks.TaskCanceledException)
                        //connection.LogTransaction(ctrl, "ThreadAbortEsception");
                        Debug.WriteLine("Cancel Exception");
                        connection.UpdateFailedCad(ctrl, array, "false");
                if (result.JobStatus == GPJobStatus.Succeeded)
                    var outParam = await gp.GetResultDataAsync(result.JobID, "Output_File") as GPDataFile;
                    if (outParam != null && outParam.Uri != null)
                        //OficialCatUri = outParam.Uri;
                        string fileName = @"\" + template + ".pdf";
                        try
                            storePath = MakeStoreFolder(ctrl, fileName);
                            string save = LoadUriPdf(outParam.Uri, storePath, fileName);
                            Objects.path = storePath;
                        catch (Exception e)
                            //Debug.WriteLine("Error: ", e.ToString());
                            connection.LogTransaction(ctrl, e.Message);
                            Objects.path = "Error";
                else
                    if (result.JobStatus ==GPJobStatus.Failed){
                        return "failed";
                    if (result.JobStatus == GPJobStatus.TimedOut)
                        return "time out";
            catch (Exception e)
                connection.LogTransaction(ctrl, e.Message +" "+ ctrl);
            return storePath;
Values returned by result after calling await gp.SubmitJobAsync(parameter):
However if I call the geoprocessing task from rest endpoint it works and sends the correct output.
Is there something wrong with the authentication or the code?
Should I deal with status New and no JobID or any ideas on how do I fix this situation?
do i need to migrate to a newer version of the sdk?
Regards,
Diego Llamas
MichaelBranscomb
Esri Frequent Contributor
ArcGIS Runtime components are not currently supported for use in internet-/server-/service- based scenarios. It is a requirement we are monitoring and we hope to be able to support this use case in the future.
There are ways of extending ArcGIS Server to implement your behavior - for more info see About extending services—Documentation | ArcGIS Enterprise
Regards
Mike
